Blenderkit: Breaks keymap type "Window" #67565
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#67565
Operating system: win64
Broken:
2.80, 45ae9edbd5ac, blender2.8, 2018-07-25,
Keymap registration in Blenderkit Breaks Key map unregister "Window Type" in Viewport Pie Menu addon and likely causes error in addons load tests.
Enable Blenderkit addon
Enable Viewport pie menu's addon then in the addons preferences enable all or only the editor switch pie.
Disable Blenderkit
Disable Viewport pie menu's.
Error:
Please note: The viewport pies addon registers and unregister and correctly removes the keymap from the "Window" keymaps when enabled without Blenderkit enabled then disabled. I believe this may have been the cause of the issues here
9792985119
due to order of enable disable in the addons load tests Resulting in my commits to the pie menus reverted. I'm not looking to change the pie menu's again until after release.The bug in Blenderkit needs to be addressed asap. Priority should be high and fix should be in before release.
I would like to thank @Imaginer for his help in irc on this matter and the time spent testing this unusual circumstance. A edited copy of his report back.
blenderkit gets unregistered before your addon and it's not, you see both addons add hotkeys to the 'Window' keymap.
When blenderkit removes the keymap it seems to go to far and messes up the 'Window' keymap
To verify just enable all addons except blenderkit and try a factory reset
Or just enable yours and blenderkit, then disable blenderkit and disable yours and you can replicate without doing a factory reset
[I'm wondering if it's something to do with a persistent property it registers on the keymap?
sorry, kmi.properties.keep_running
got solution for you
error in km, kmi for loop
replace lines 1692-1694 in ui.py with the normal unregistration and you'll need to replace the addon_keymaps append line in register.
@ideasman42 @brecht @VilemDuha
Added subscribers: @Imaginer, @ideasman42, @VilemDuha, @brecht, @BrendonMurphy
Adding highest priority as this should be fixed before release.
Just to clarify. When blenderkit registers it only stores the keymap in addon_keymaps; it doesn't store the keymap_item as well. When it unregisters the hotkey in ui.py it then uses "wm.keyconfigs.addon.keymaps.remove(km)" instead of km.**keymap_items.**remove(kmi) and so removes the entire "Window" keymap instead of just the hotkey it created. This then causes any other addons that try to remove hotkeys from the "Window" keymap to fail.
This issue was referenced by
5fdd75d683
Resolved by commit
5fdd75d683
