Import .obj with more than one unnamed object fails. #67673
Reference: blender/blender#67673
Operating system: Darwin-17.7.0-x86_64-i386-64bit 64 Bits
Graphics card: NVIDIA GeForce GTX 1080 Ti OpenGL Engine NVIDIA Corporation 4.1 NVIDIA-10.33.0 387.10.10.10.40.122
Broken: version: 2.80 (sub 74), branch: master, commit date: 2019-07-18 14:52, hash:
38d4483c6a
Worked: (2.79b)
Based on the default startup
File > Import > Wavefront (.obj) attached files
One unnamed object is ok
single_unnamed.obj
Two named objects are ok
two_named.obj
Two unnamed fails :
two_unnamed.obj
TypeError: %b requires a bytes-like object, or an object that implements bytes, not 'NoneType'
Added subscriber: @ph-1
Added subscriber: @rjg
The function
unique_name
fails to generate unique names when the providedname_orig
isNone
. I'm not sure if empty names are allowed in the format, it's not mentioned in the spec. This could be fixed by generating a random name.What software produced these .obj files?
Added subscriber: @mont29
@mont29 Your opinion on this?
I produced those 3 .obj files by hand with some basic cube example to illustrate the problem.
I noticed this while working on a threejs project. I first thought it was due to a malformed exported file and yes the file has some issues, but checking against blender 2.79 it worked
I could provide it if really needed but with basic example the problem stays the same.
The traceback indicates unique_name, I tried naming objects and the problem was gone.
I think it's a bug because as you said it's not mentioned in the spec and other 3D softwares have no problem opening those files.
Here you can check other .obj produced by threejs . I made 2 files from the "multiple" example with objects names (added by me, works) and without (default export, fails) so you can try:
named.obj unnamed.obj
The behavior in 2.79b is different, but the import of multiple unnamed objects doesn't work there either. It just imports one of them.
Now the question is whether your handcrafted files are considered valid .obj format and therefore should be supported. That isn't my call to make, one of the devs or project owners has to decide.
@rjg You're right, it doesn't work the same but at least it imports something :)
Will check how to handle multiple unamed objects...
This issue was referenced by blender/blender-addons@5f579088bb
