View Selected in Graph Editor (Only Selected Curve Keyframes) takes hidden keys into account when calculating zoom #67873
Closed
opened 2019-07-29 09:14:50 +02:00 by Roman · 8 comments
Graphics card: GeForce GTX 750 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 388.13
Broken: version: 2.80 (sub 75), branch: master, commit date: 2019-07-24 14:22, hash: 507ffee6e1
Selects hidden Vertex When Only Selected Curve keyframes is enabled,graph_editor_zoom.blend
{F7634778}]
When Only Selected Curve keyframes is enabled, the hidden Vertex is Selects.
View Selected command does not work correctly
**System Information** Operating system: Windows-7-6.1.7601-SP1 64 Bits Graphics card: GeForce GTX 750 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 388.13 **Blender Version** Broken: version: 2.80 (sub 75), branch: master, commit date: 2019-07-24 14:22, hash: `507ffee6e1` Worked: (optional) **Short description of error** Selects hidden Vertex When Only Selected Curve keyframes is enabled,[graph_editor_zoom.blend](https://archive.blender.org/developer/F7634777/graph_editor_zoom.blend) {[F7634778](https://archive.blender.org/developer/F7634778/Zoom3.gif)}] **Exact steps for others to reproduce the error** When Only Selected Curve keyframes is enabled, the hidden Vertex is Selects. View Selected command does not work correctly [Based on the default startup or an attached .blend file (as simple as possible)]
Author
Added subscriber: @roman-13
Member
Added subscriber: @lichtwerk
Philipp Oeser self-assigned this 2019-07-29 10:00:37 +02:00
Member
Can confirm.
Same is true for 2.79 (so not 100% sure this is intended in certain scenarios?).
Confirming for now though, seems reasonable to only frame selected curves keyframes (if this setting is enabled...)
Can confirm. Same is true for 2.79 (so not 100% sure this is intended in certain scenarios?). Confirming for now though, seems reasonable to only frame selected curves keyframes (if this setting is enabled...)
Added subscriber: @Pavel_Blend
This behavior also bothers me.
If you enable the "Only Selected Curve Keyframes" mode, then when you press the A key, hidden keyframes will be selected.
I would like the A key select to only visible keyframes.
This behavior also bothers me. If you enable the "Only Selected Curve Keyframes" mode, then when you press the A key, hidden keyframes will be selected. I would like the A key select to only visible keyframes.
Added subscriber: @StanislavOvcharov
Philipp Oeser changed title from View Selected in Graph Editor to View Selected in Graph Editor (Only Selected Curve Keyframes) takes hidden keys into account when calculating zoom 2019-11-12 18:47:58 +01:00
This issue was referenced by 355905cb02
This issue was referenced by 355905cb0278c368059fdecef8735b731d97b97c
Member
5 Participants
Reference: blender/blender#67873
