Object Importer Error #67889
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
5 Participants
Reference: blender/blender-addons#67889
Graphics card: Intel(R) HD Graphics 620 Intel 4.5.0 - Build 23.20.16.4973
Broken: version: 2.80 (sub 75), branch: master, commit date: 2019-07-24 14:22, hash:
blender/blender@507ffee6e1
Certain Obj files will not import and throws an error
ValueError: math domain error
Use Release candidate 3 and just use the Object:
3DS - The Legend of Zelda Ocarina of Time 3D - Gerudo Mask.zip
Added subscriber: @ConsUme
Added subscriber: @lichtwerk
Confirmed, checking...
Added subscriber: @mont29
Looks like the material file specifies a negative specular exponent... [this should not be allowed imho]
I guess we should just clamp this to min 0.0, but will check with others...
Also: seeing this has actually been exported from blender: checked, and we actually allow negative specular exponent [if roughness is above 1.0 -- which we seem to allow as well...] to be exported [should not be allowed I guess, see above...]
Not sure if this could/should be clamped in our material (node) system, or on export, will check with others as well...
CC @mont29
Added subscriber: @dr.sybren
This code can only produce negative specularity if the roughness is a complex number. Squaring the number using
spec *= spec
makes it absolute, hence nonnegative.IMO we should handle out-of-range values gracefully, either rejecting the material altogether or clamping the values.
oops, true, wasnt paying attention that it gets squared... I wonder how this got exported from blender then (I mean how it got negative)?
Exported from Blender 2.75.... That's an old geezer, who knows what it was doing at that time? ;)
Seriously, yes, we should clamp those values on import to a valid range, just safer. Probably even in the material wrapper thingy, such that all IO scripts could benefit from it.
This issue was referenced by
27381001d7
