Cryptomatte not rendering alpha and diffuse #67946
Reference: blender/blender#67946
{F7638044}System Information
Operating system: Windows 10
Graphics card: GeForce GTX 1080
Broken: (example: 2.80,
edbf15d3c0
, master, 2018-11-28, as found on the splash screen) 2.80 latest release July 30. Cant find other info.Worked: (optional)
Setup Cryptomatte as explained in manual.
Set renderer to cycles
enabled Cryptomatte Object mode
setup Post Nodes with render layer going in to cryptomatte and then in to viewer.
assigned object to layer in the cryptomatte node.
rendered
only the pick node is created, no image, no alpha
rendered
only the pick node is created, no image, no alpha{F7637902}
Added subscriber: @grimsby
Added subscriber: @dark999
You forgot to upload a simplest possible .blend file to reproduce this issue
Added subscriber: @brecht
The attach .blend file works for me if render, and then use the Add button to pick the cube. The cube is then shown in the Render Result output.
The value it picks here is
<-2.80784053e-14>
, is that the same for you?No I get <0.341914415>
If I manually plug in the number you provided, it works.
But I don't get that number with the eyedropper.
figured it out. my error. coming from other packages since it was an object ID I assumed you picked the object. But you have to pick the objects color in the render.
Not very intuitive.
