Not opening on Screen1 like it used to? #67955
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#67955
Operating system:
Graphics card:
2.80 Release
Broken:
(example: 2.79b release)
Er.. Uhm.. Just opening it.. :)
Added subscriber: @BorsingStudios
DxDiag.txt
Added subscriber: @GavinScott
Please provide your operating system and video card info. Also please describe what it's doing that you think is incorrect. Is it opening on the wrong screen? If you position Blender's window(s) where you want them and then do FIle->Defaults->Save Startup File then it should return to the same setup each time you start.
Added subscriber: @mont29
Tried position Blender's window(s) where you want them and then do FIle->Defaults->Save Startup File then it should return to the same setup each time you start.
Same result every time, will NOT open on main screen..
