Extend Horizontal (RGB Curves Node) does not work outside the Clipping boundaries #67981
Reference: blender/blender#67981
Broken: 2.80, 2.79
The Extend Horizontal option of the Compositor's RGB Curves Node
does not work (acts as Extrapolated) outside the boundaries set by the Clipping option.
In the Shader Editor, Extend Horizontal works if the endpoint is in the range [0,1],
but if the endpoint is outside [0,1] it acts as the Extrapolated.
compositor:
shader editor:
curve-visualizer-compositor.blend
curve-visualizer-shader.blend
Added subscriber: @jenkm
Added subscribers: @Jeroen-Bakker, @lichtwerk
Can confirm for the compositor.
@Jeroen-Bakker: mind having a look here?
Having trouble reproducing the shader example, seems to work fine here (2.8
af4dcc6073
)?curve-visualizer-shader-no-repro.blend
@jenkm: mind attaching a file (already set up to show the failing in the shader case -- might have done something wrong in my file...)
curve-visualizer-shader-2.blend
set the endpoint to 1.25
it looks correctly in the Look Dev:
but Render wrong:
Operating system: Darwin-18.6.0-x86_64-i386-64bit 64 Bits
Graphics card: AMD Radeon Pro 455 OpenGL Engine ATI Technologies Inc. 4.1 ATI-2.9.26
Broken: version: 2.81 (sub 0), branch: master, commit date: 2019-07-30 20:50, hash:
5359b7a033
Ah, OK, get it, thx for getting back
Seems to be a dual state problem.
The CRGB curves stores the
horizontal extension
per curve C, R, G and B. when evaluating the curves only the horizontal extension of the R, G and B channels are checked. The setting in the C-curve is ignored completely. In the files provided the C channel only has the horizontal extension turned on the rest of the channels are turned off hence the extension is not available. I would suggest that this is not a small change, but we needs some overall guidance how this control needs to work. And based on the outcome of this we should make sure all users use the component the same manner.an option would be to always draw all curves in the control, so the user sees better what happens. Another option would be to only have a single
stored that is used by all 4 curves (limits current implementation, but perhaps easier to understand). The second option will break current files.Added subscriber: @brecht
@brecht how can we move forward with this issue? I checked with Bastien, he proposed to check with you.
To me this seems like the right solution, even if it breaks compatibility.
