Skyrocketing (infm) values when disabling Continuous Drag #68130
Closed
opened 2019-08-02 14:09:39 +02:00 by Meshington · 9 comments
Windows 8.1 64 bits
Broken: Blender 2.80 release
Worked: Blender 2.79
When changing values for ‘Dimensions’ with the slider, the values goes to “infm”
Exact steps for others to reproduce the error (via attached blend file)
  1. Load attached .Blend, or your own.
  2. Disable ‘continuous drag’ (Preferences->Input)
  3. Make sure the cube is selected
  4. In the sidebar of 3d view->’Dimensions’ change value in any of X, Y, Z by dragging.
    5... Notice how the value skyrockets with just small mouse movements.
(This might(?) happen with ‘Rotate' as well, but not nearly as high value.)
AimingForMars.blend
**System Information** Windows 8.1 64 bits **Blender Version** Broken: Blender 2.80 release Worked: Blender 2.79 **Short description of error** When changing values for ‘Dimensions’ with the slider, the values goes to “infm” **Exact steps for others to reproduce the error (via attached blend file)** 1. Load attached .Blend, or your own. 2. Disable ‘continuous drag’ (Preferences->Input) 3. Make sure the cube is selected 4. In the sidebar of 3d view->’Dimensions’ change value in any of X, Y, Z by dragging. 5... Notice how the value skyrockets with just small mouse movements. (This might(?) happen with ‘Rotate' as well, but not nearly as high value.) [AimingForMars.blend](https://archive.blender.org/developer/F7645585/AimingForMars.blend)
Author
Added subscriber: @Meshington
Member
Added subscribers: @ideasman42, @lichtwerk
Member
@ideasman42 : I have added this to 2.81 milestone (since it was set to "High"), mind checking again?
Added subscriber: @gnastacast
I see an easy fix to this. The problem is in view3d_buttons.c
It's the way this problem has been fixed everywhere else but it's frankly kind of hacky.
I made a diff for it but I didn't submit it because it still seems like every time a button is created with a float value, the limit is set arbitrarily. In my mind you should be able to set the limits to +- FLT_MAX without breaking everything. I couldn't find where click and drag was implemented for the buttons but I feel like that is where the fix should be applied, not as it was here https://developer.blender.org/D5454?id=17055 and so many other places in the code base.
dimension_drag.diff
I see an easy fix to this. The problem is in view3d_buttons.c It's the way this problem has been fixed everywhere else but it's frankly kind of hacky. I made a diff for it but I didn't submit it because it still seems like every time a button is created with a float value, the limit is set arbitrarily. In my mind you should be able to set the limits to +- FLT_MAX without breaking everything. I couldn't find where click and drag was implemented for the buttons but I feel like that is where the fix should be applied, not as it was here https://developer.blender.org/D5454?id=17055 and so many other places in the code base. [dimension_drag.diff](https://archive.blender.org/developer/F7822742/dimension_drag.diff)
Added subscriber: @dfelinto
@ideasman42 I believe this is fixed now, right?
This issue was referenced by 490d5bb750
This issue was referenced by 490d5bb7508aa700990871358af5c2ad5fcf5716
Campbell Barton self-assigned this 2019-11-05 04:13:06 +01:00
Thomas Dinges added this to the 2.81 milestone 2023-02-08 16:48:10 +01:00
6 Participants
Reference: blender/blender#68130
