Crash when smoke type switch from Flow to Domain with Cycles viewport rendering
Graphics card: 67EF:CF ATI Technologies Inc. 4.5.13474 Core Profile Context 22.19.162.4
Crash when smoke type switch from Flow to Domain with Cycles viewport rendering.
  1. Use Cycles
  2. Add Quick Smoke
  3. Change Smoke Type to Flow
  4. Swhitch viewport to Rendered
  5. Change Smoke Type to Domain
  6. Crash
Philipp Oeser (lichtwerk) triaged this task as Confirmed, Medium priority.
Confirmed, checking...
Setting smoke type already does rna_Modifier_dependency_update and thus DEG_relations_tag_update(bmain), so not sure if there is more to be done on the blender side...
Crash is in cycles BVH refitting, if the BVH is rebuilt instead, all is fine...
quick proof: following seems to work, but there is probably a more elegant way to do this (or a completely other solution alltogether)...
1
2
3diff --git a/intern/cycles/blender/blender_mesh.cpp b/intern/cycles/blender/blender_mesh.cpp
4index c672bc9f3e2..ae789aaa47c 100644
5--- a/intern/cycles/blender/blender_mesh.cpp
6+++ b/intern/cycles/blender/blender_mesh.cpp
7@@ -1002,6 +1002,14 @@ Mesh *BlenderSync::sync_mesh(BL::Depsgraph &b_depsgraph,
8 oldcurve_keys.steal_data(mesh->curve_keys);
9 oldcurve_radius.steal_data(mesh->curve_radius);
10
11+ /* ensure bvh rebuild if smoke type changed from flow to domain, not sure why... */
12+ bool oldhas_voxel_attributes = false;
13+ foreach (Attribute &attr, mesh->attributes.attributes) {
14+ if (attr.element == ATTR_ELEMENT_VOXEL) {
15+ oldhas_voxel_attributes = true;
16+ }
17+ }
18+
19 mesh->clear();
20 mesh->used_shaders = used_shaders;
21 mesh->name = ustring(b_ob_data.name().c_str());
22@@ -1048,9 +1056,17 @@ Mesh *BlenderSync::sync_mesh(BL::Depsgraph &b_depsgraph,
23 sync_mesh_fluid_motion(b_ob, scene, mesh);
24
25 /* tag update */
26+ bool has_voxel_attributes = false;
27+ foreach (Attribute &attr, mesh->attributes.attributes) {
28+ if (attr.element == ATTR_ELEMENT_VOXEL) {
29+ has_voxel_attributes = true;
30+ }
31+ }
32+
33 bool rebuild = (oldtriangles != mesh->triangles) || (oldsubd_faces != mesh->subd_faces) ||
34 (oldsubd_face_corners != mesh->subd_face_corners) ||
35- (oldcurve_keys != mesh->curve_keys) || (oldcurve_radius != mesh->curve_radius);
36+ (oldcurve_keys != mesh->curve_keys) || (oldcurve_radius != mesh->curve_radius) ||
37+ (oldhas_voxel_attributes != has_voxel_attributes);
38
39 mesh->tag_update(scene, rebuild);
40
T58569 is the same thing really...
