Hardware: Tablets: Problem with Trust Panora Widescreen graphic tablet #68496
6 Participants
Reference: blender/blender#68496
Operating system: Wind 10 ( 64 bit )
Graphics card: ( Nvidia RTX 2080 )
Broken: 2.80 from 08.09.2019 , also 2,79b from the same day )
There are tow problems , first is that when i enter sculpting mode , work for a bit of time and then minimize blender in the background and then come back to blender , it makes a mess out of the mouse cursor ( is not detecting it anymore , and when i click anywhere it auto locks the mouse cursor on the top of the screen and it takes me out of blender ) .
The second problem is that the size pressure and strength pressure options do not function even if they are enabled (for the brushes ) . I have the latest drivers for the tablet installed .
These problems are limited to Blender only , in other programs like Zbrush , Krita , Paint they are not present and everything works ok .
Added subscriber: @Xotherz
Ok , after a few days of speaking with the support team from Trust we found a workaround fix for the problem . First without the tablet connected to the pc go in Blender , Preferences , Input , Tablet , Tablet API and change it to Windows Ink , save and exit Blender . Connect you tablet to your pc , go in task bar and open its program PenTabletSettings , go to Tablet 1 ( 10.00x6.00 ) and check the box for Support Tablet PC . Now go start Blender , go into Preferences again ,Input , Tablet , Tablet Api and chance it from Windows Ink to Wintab , and close dawn the Prefecrences tab . Now go back in Preferences , input , tablet , tablet Api and change it back again to windows ink , close dawn the preference tab and now the tablet should work just fine . Yeah , is kinda strange i know but it works . Note that you have to do this every time you start a new session of blender ( by that i mean changing the API back and forward like that ) , also note that with the ,, Support Tablet PC '' option turned one some other programs like for example ZBrush will not work right ( you lose for example the pressure sensitivity feature in Zbrush with it on ) . Hope this helps others .
Problem with Trust Panora Widescreen graphic tabletto Hardware: Tablets: Problem with Trust Panora Widescreen graphic tabletAdded subscribers: @ChristopherPeerman, @lichtwerk
@ChristopherPeerman: I cant check this myself [I'm on linux], does this ring a bell?
Since then TRUST updated there drivers. but as far as i know they did not fix this issue . The table still runs ok on anything aside from Blender for some reason . I dont know of a fix for MAC or Linux sorry . I will add a pdf file explaining the fix for windows that was provided to me by the TRUST support team . Blender workaround.pdf
Added subscriber: @Jeroen-Bakker
Changed status from 'Needs Triage' to: 'Needs Developer To Reproduce'
In order to add support for specific device we need to be able to have access to the device. So marking this for now as Known Issue, with low priority and needs developer to reproduce.
Added subscriber: @brecht
Changed status from 'Needs Developer To Reproduce' to: 'Needs User Info'
There have been significant changes to tablet handling on Windows today. Can you verify if this is still an issue in the latest build?
https://builder.blender.org/download/
Hi , so after a quick test on the latest Blender build and updated the tablet driver this is the result : the problem with the mouse cursor is fixed . Pressure detection dose not work or dose not work as it should . Set on windows ink it dose not work at all , set on WinTab it works ( kinda - seems to have some problems to output detail but that might be from the settings ) but the brushes are inverted - subtract adds and add subtracts .
Update : setting wintab in blender and then enabling: ,,Support Tablet PC'' in the tablets settings fixed the pressure and detection problems !
Added subscriber: @PrototypeNM1
@Xotherz Could you upload a screencap of the tablet settings where you changed "Support Tablet PC"? If there are any dropdowns on the same page it might help to screencap them too.
@Xotherz if you are having any problems with recent nightly builds, could you recreate the issue in this build and copy the resulting output to the system console here?
I made a few tests on the newest version of 2.83 ( f418eddf8e1c-windows64)
I testes the the fallowing :
Windows Ink - ON ; Support Tablet PC - OFF = no cursor bug but pressure sensitivity dose not work
Window Ink - ON , Support Tablet PC - ON = no cursor bug and the pressure sensitivity works ok
WinTab - ON ; Support Tablet PC - ON = cursor bug is back
WinTab -ON ; Support Tablet PC - OFF = cursor bug is back
results of the special version of Blender given in the link 2.90 :
Console :
Read prefs: C:\Users\xothe\AppData\Roaming\Blender Foundation\Blender\2.90\config\userpref.blend
AL lib: (EE) UpdateDeviceParams: Failed to set 48000hz, got 176400hz instead
AL lib: (EE) SetChannelMap: Failed to match front-center channel (2) in channel map
lcOutOrgX: 0, lcOutOrgY: 0, lcOutExtX: 1920, lcOutExtY: -1080
left: 0, top: 0, width: 1920, height: 1080
initializeWintab numDevices: 1
initializeWintab maxPressure: 2048
initializeWintab queueSize: 500, queueSizeGet: 500
initializeWintab cursor 0 buttons
0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31,
1, 4, 7, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
initializeWintab cursor 1 buttons
1, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
initializeWintab cursor 2 buttons
updateWintab enable: 1, overlap: 1
found bundled python: C:\Users\xothe\Downloads\bin\2.90\python
Info: Deleted 1 object(s)
updateWintab enable: 1, overlap: 0
updateWintab enable: 0, overlap: 0
**Window Ink - ON , Support Tablet PC - ON = no cursor bug and the pressure sensitivity works ok
COnsole : **
WinTab - ON ; Support Tablet PC - ON = no cursor bug , pressure sensitivity works
Console :
processWintabProximityEvent inRange: 1
wintabMouseToGhost left click
wintab button down
wintab button associated to system button
1 system buttons
wintab button up
0 system buttons
wintab button down
1 system buttons
wintab button up
0 system buttons
wintab button down
1 system buttons
wintab button up
0 system buttons
wintab button down
1 system buttons
wintab button up
0 system buttons
wintab button down
1 system buttons
wintab button up
0 system buttons
processWintabProximityEvent inRange: 0
wintab button down
1 system buttons
wintab button up
0 system buttons
wintab button down
1 system buttons
wintab button up
0 system buttons
wintab button down
1 system buttons
wintab button up
0 system buttons
wintab button down
1 system buttons
wintab button up
0 system buttons
wintab button down
1 system buttons
wintab button up
0 system buttons
wintab button down
1 system buttons
wintab button up
0 system buttons
wintab button down
1 system buttons
wintab button up
0 system buttons
wintab button down
1 system buttons
wintab button up
0 system buttons
wintab button down
1 system buttons
wintab button up
0 system buttons
wintab button down
1 system buttons
wintab button up
0 system buttons
wintab button down
1 system buttons
wintab button up
0 system buttons
wintab button down
1 system buttons
wintab button up
0 system buttons
wintab button down
1 system buttons
wintab button up
0 system buttons
updateWintab enable: 0, overlap: 1
wintab button down
1 system buttons
wintab button up
0 system buttons
wintab button down
1 system buttons
wintab button up
0 system buttons
WinTab -ON ; Support Tablet PC - OFF = no cursor bug , pressure sensitivity dose not work at first , resumes working after a minimize of Blender and the going back in
Console:
wintab button down
1 system buttons
wintab button up
0 system buttons
wintab button down
1 system buttons
wintab button up
0 system buttons
wintab button down
1 system buttons
wintab button up
0 system buttons
wintab button down
1 system buttons
wintab button up
0 system buttons
wintab button down
1 system buttons
wintab button up
0 system buttons
wintab button down
1 system buttons
wintab button up
0 system buttons
wintab button down
1 system buttons
wintab button up
0 system buttons
wintab button down
1 system buttons
wintab button up
0 system buttons
wintab button up
0 system buttons
wintab button down
1 system buttons
wintab button up
0 system buttons
wintab button down
1 system buttons
wintab button up
0 system buttons
wintab button down
1 system buttons
wintab button up
0 system buttons
wintab button down
1 system buttons
wintab button up
0 system buttons
wintab button down
1 system buttons
wintab button up
0 system buttons
wintab button down
1 system buttons
wintab button up
0 system buttons
For Wintab On Tablet PC Off, is it specifically minimizing the window and not just changing to another window that gets pressure to work again? Could you add notes to the following for the window is minimized and maximized?Edit: I understand the issue now, and thinking of solutions.
wintab button down
The issue is that during creation of the window, there's a period of time where the window is asynchronously being shown and remains iconic (no visible window). Currently when the tablet api is setup it relies on this isiconic detail before it is guaranteed to be true, so we have a race condition. Why this isn't an issue when Support Tablet PC is set is anyone's guess; maybe it forces synchronization behind the scenes before the window creation returns or maybe it just creates a timing difference.
@Xotherz Could you try this updated build for Wintab On Tablet PC Support Off?
Hi , so i did 4 more tests on : Wintab On Tablet PC Support Off
1 - fresh power up of the pc , first thing starting Blender = everything works as it should - pressure works and no cursor bug
2 - close Blender and start it back again = no cursor bug , pressure sensitivity dose not work
3- close Blender again and start it back up = no cursor bug , pressure sensitivity dose not work , minimize Blender and going back in = pressure sensitivity works again
4 - close Blender again and going back in = no cursor bug , pressure sensitivity dose not work , go in the ,,Save as '' men ( not making an actual save , just going in the menu and exiting after) - pressure sensitivity resumes working
TEST 1 :
10be0 updateWintab enable: 1, overlap: 1
found bundled python: C:\Users\xothe\Downloads\blender-2.90.0-git20200424.6ea5a4d7e766-windows64\2.90\python
10be0 updateWintab enable: 1, overlap: 0
201c0 updateWintab enable: 1, overlap: 1
10be0 WT_PROXIMITY loword (!0 enter 0 leave context): 1, hiword (!0 enter !0 leave hardware): 1
10be0 processWintabProximityEvent inRange: 1
10be0 WT_CSRCHANGE
10be0 WT_PROXIMITY loword (!0 enter 0 leave context): 51216, hiword (!0 enter !0 leave hardware): 0
10be0 wintabMouseToGhost left click
10be0 wintab button down
10be0 wintab button associated to system button
10be0 1 system buttons
10be0 wintab button up
10be0 0 system buttons
10be0 WT_PROXIMITY loword (!0 enter 0 leave context): 0, hiword (!0 enter !0 leave hardware): 1
10be0 processWintabProximityEvent inRange: 0
10be0 WT_CSRCHANGE
10be0 WT_CSRCHANGE
10be0 WT_CSRCHANGE
10be0 WT_CSRCHANGE
10be0 WT_CSRCHANGE
10be0 updateWintab enable: 0, overlap: 0
10be0 WT_PROXIMITY loword (!0 enter 0 leave context): 0, hiword (!0 enter !0 leave hardware): 0
10be0 WT_PROXIMITY loword (!0 enter 0 leave context): 1, hiword (!0 enter !0 leave hardware): 0
10be0 WT_CSRCHANGE
10be0 WT_CSRCHANGE
10be0 WT_CSRCHANGE
KeyboardInterrupt
TEST 2 :
20be2 updateWintab enable: 1, overlap: 1
20be2 updateWintab enable: 0, overlap: 0
20be2 WT_PROXIMITY loword (!0 enter 0 leave context): 1, hiword (!0 enter !0 leave hardware): 1
20be2 processWintabProximityEvent inRange: 1
20be2 WT_CSRCHANGE
20be2 WT_PROXIMITY loword (!0 enter 0 leave context): 51216, hiword (!0 enter !0 leave hardware): 0
20be2 wintabMouseToGhost left click
20be2 wintab button down
20be2 wintab button associated to system button
20be2 1 system buttons
20be2 wintab button up
20be2 0 system buttons
20be2 WT_PROXIMITY loword (!0 enter 0 leave context): 0, hiword (!0 enter !0 leave hardware): 1
20be2 processWintabProximityEvent inRange: 0
20be2 WT_CSRCHANGE
20be2 WT_CSRCHANGE
20be2 updateWintab enable: 1, overlap: 0
TEST 3 :
30bee updateWintab enable: 1, overlap: 1
30bee updateWintab enable: 0, overlap: 0
30bee WT_PROXIMITY loword (!0 enter 0 leave context): 1, hiword (!0 enter !0 leave hardware): 1
30bee processWintabProximityEvent inRange: 1
30bee WT_CSRCHANGE
30bee WT_PROXIMITY loword (!0 enter 0 leave context): 51216, hiword (!0 enter !0 leave hardware): 0
30bee wintabMouseToGhost left click
30bee wintab button down
30bee wintab button associated to system button
30bee 1 system buttons
30bee wintab button up
30bee 0 system buttons
30bee WT_PROXIMITY loword (!0 enter 0 leave context): 0, hiword (!0 enter !0 leave hardware): 0
30bee processWintabProximityEvent inRange: 0
30bee updateWintab enable: 1, overlap: 0
TEST 4:
40bb6 updateWintab enable: 1, overlap: 1
40bb6 updateWintab enable: 1, overlap: 0
80c74 updateWintab enable: 1, overlap: 1
40bb6 WT_PROXIMITY loword (!0 enter 0 leave context): 1, hiword (!0 enter !0 leave hardware): 1
40bb6 processWintabProximityEvent inRange: 1
40bb6 WT_CSRCHANGE
40bb6 WT_PROXIMITY loword (!0 enter 0 leave context): 51216, hiword (!0 enter !0 leave hardware): 0
40bb6 wintabMouseToGhost left click
40bb6 wintab button down
40bb6 wintab button associated to system button
40bb6 1 system buttons
40bb6 wintab button up
40bb6 0 system buttons
40bb6 WT_PROXIMITY loword (!0 enter 0 leave context): 0, hiword (!0 enter !0 leave hardware): 1
40bb6 processWintabProximityEvent inRange: 0
@Xotherz
Could you test the same with this build?
I added additional logging information to try and figure out what's going on with wintab contexts.
Hi, i made the test again , here are the results :
1 - fresh power up of the pc , first thing starting Blender = no cursor bug , pressure sensitivity dose not work
2 - close Blender and start it back again = no cursor bug , pressure sensitivity dose not work ( just like the last time )
3- close Blender again and start it back up = no cursor bug , pressure sensitivity dose not work , minimize Blender and going back in = pressure sensitivity works again ( just like the last time )
4 - close Blender again and going back in = no cursor bug , pressure sensitivity dose not work , go in the ,,Save as '' men ( not making an actual save , just going in the menu and exiting after) - pressure sensitivity resumes working ( just like the last time )
Added subscriber: @EitanSomething
Can you please put the above test information in a text because it is very long.
closse start again minimize.txt
first boot up.txt
close start back again.txt
close start again enter save -as menu.txt
Can you also delete the comments. thank you
@Xotherz @EitanSomething I've found having these logs inline very helpful for the debugging workflow, and at a glance uploading as text will be very disruptive.
@EitanSomething could you jump onto Blender chat?
@Xotherz I talked with Eitan, the best place to upload future logs would be https://developer.blender.org/paste/edit/form/default/. If you want to clean up the older posts with logs no need to re-upload anything; I can find the old logs it in the post's edit history.
If you run multiple tests it's most convenient if you put them all in a single paste similar to the single reply you were doing before.
For reference, here's the last set of logs P1360.
Looking through the logs this is a driver bug, there is an erroneous context overlap that that occurs on startup.
@Xotherz Could you send me the contact information you used to contact Trust support (I couldn't find an email on their website)?
I'm going to close the issue given the work to fix this is on Trust's side, but I'll keep this thread posted on when I'm able to get in contact with them.
support.en@trust.com
this is where i spoke with them
I messaged the bug details to Trust, so hopefully they'll be able to work through the issue.
If I hear back that they've fixed the issue I'll update this report, otherwise assume that I never received confirmation of a fix.
