caps lock shortcut crash #68637
Closed
opened 2019-08-14 11:34:52 +02:00 by Andrej Šándor · 5 comments
Graphics card: GeForce GTX 1080 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 430.39
Broken: version: 2.80 (sub 60), branch: master, commit date: 2019-05-09 10:46, hash: f877022956
Blender crashes whenever i want assign "caps lock" as an shortcut. anywhere. (you should consider to use that button for more efficient pivot snaping ;) )
best regards Andrej
Right click on (anywhere where you can assign a shortcut). press "Caps Lock" for assignment. blender crashed.
**System Information** Operating system: Windows-10-10.0.17763 64 Bits Graphics card: GeForce GTX 1080 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 430.39 **Blender Version** Broken: version: 2.80 (sub 60), branch: master, commit date: 2019-05-09 10:46, hash: `f877022956` Worked: (optional) **Short description of error** Blender crashes whenever i want assign "caps lock" as an shortcut. anywhere. (you should consider to use that button for more efficient pivot snaping ;) ) best regards Andrej **Exact steps for others to reproduce the error** Right click on (anywhere where you can assign a shortcut). press "Caps Lock" for assignment. blender crashed. [Please describe the exact steps needed to reproduce the issue] [Based on the default startup or an attached .blend file (as simple as possible)]
Added subscriber: @Shalfandor
Added subscriber: @ChristopherAnderssarian
Can confirm here...
Can confirm here...
This issue was referenced by d2195d9ef2
This issue was referenced by d2195d9ef24a0c8f9098e4791cf18468ba805dba
Campbell Barton self-assigned this 2019-08-14 13:47:22 +02:00
Reference: blender/blender#68637
