Weight Tools: Limit Total does not seem to set the requested limit #68668
Reference: blender/blender#68668
Operating system: Linux (Arch)
Graphics card: Nvidia GTX 970
Broken: 2.80 (sub 75),
f6cb5f5449
I have a model that (apparently) has more than 5 bones influencing certain vertices.
I'm exporting to a game engine that only supports 4 bones per vertex.
When I run
Weight Tools > Limit Total
with a value of 4 or even 3, I still seem to have some vertices with 5 groups.Only by running
with a value of 2 can I get within the limit (at which point I have several vertices with 3 groups.If this is actually working as intended, https://docs.blender.org/manual/en/latest/sculpt_paint/weight_paint/editing.html#limit-total should be updated to reflect the behavior.
len(v.groups) for v in C.object.evaluated_get(C.view_layer.depsgraph).to_mesh(preserve_all_data_layers=True, depsgraph=C.view_layer.depsgraph).vertices if len(v.groups) > 4]
[5, 5, 5, 5]
(4 vertices have 5 groups each)[5, 5, 5, 5]
(4 vertices have 5 groups each)[3, 3, 3, 3]
(4 vertices have 3 groups each)Added subscriber: @rcorre-3
Added subscriber: @robbott
I cannot reproduce this bug with:
Operating system: Darwin-18.7.0-x86_64-i386-64bit 64 Bits
Graphics card: AMD Radeon Pro 560X OpenGL Engine ATI Technologies Inc. 4.1 ATI-2.11.20
version: 2.82 (sub 3), branch: master, commit date: 2019-12-03 15:20, hash:
574a59dfb0
If you reproduce this bug with the latest blender from https://builder.blender.org/download, please reopen this task and share the blend file.
I can still repro on:
Blender 2.82 (sub 7) (build hash:
375c7dc4ca
)From the attached file, select the mesh object and run:
I see:
This is after running
Limit Total
withAll Groups
andLimit=4
. If I run it again I see "0 vertex weights limited", though the above output shows many groups with 5 weights.Robo.blendAdded subscriber: @ankitm
for a workaround, limit it to 3 & there's no
- [x]
. Many 4's though.tested on:
2b7d5caae8
Changed status from 'Archived' to: 'Needs Triage'
I was able to reproduce it, but I think it's an intended design and not a bug. You still have a mirror modifier on the mesh and the "Weights > Limit total" function tries to clean the mesh before applying the modifiers but the "C.object.evaluated_get" call will get the mesh after applying all modifiers. Please apply the mirror modifier and then use the "Limit total" function.
Just for the sake of reproducability, the correct code to run is (the first [ was missing):
Thanks Jean! Applying the mirror modifier before limiting does seem to work.
Added subscriber: @mano-wii
So, if I understand correctly the problem here is that you are reading the result of the mesh evaluated by the modifiers, which changes the value of the original weights.
It is not a bug then.
Thanks for the report.
Closing as this bug tracker is only for bugs and errors.
