Vertex snapping with median not working if the object is not at center of the world #68684
Closed
opened 2019-08-15 10:39:47 +02:00 by Christian Hubert · 5 comments
Operating system: Windows 10
Graphics card: NVidia 980M
Broken: 2.80 sub 75
Worked: 2.79
In edit mode, vertex snapping on with median option works only if the object's origin is at the center of the world.
If not, it seems there is a delta relative to the diff between its origin and the world center.
To reproduce it:
  • Start with default scene with cube
  • Duplicate it (shift D) and place it somewhere but not at the world center
  • Enter edit mode on the duplicated one
  • Turn snapping on with vertex and median target
  • Select at least two vertices
  • Try to snap to the other cube
**System Information** Operating system: Windows 10 Graphics card: NVidia 980M **Blender Version** Broken: 2.80 sub 75 Worked: 2.79 In edit mode, vertex snapping on with median option works only if the object's origin is at the center of the world. If not, it seems there is a delta relative to the diff between its origin and the world center. To reproduce it: - Start with default scene with cube - Duplicate it (shift D) and place it somewhere but not at the world center - Enter edit mode on the duplicated one - Turn snapping on with vertex and median target - Select at least two vertices - Try to snap to the other cube
Added subscriber: @christian
Member
Added subscribers: @mano-wii, @lichtwerk
Germano Cavalcante was assigned by Philipp Oeser 2019-08-15 11:14:45 +02:00
Member
Can confirm, I guess @mano-wii could have a look?
This issue was referenced by 95a0144293
This issue was referenced by 95a0144293b840bfbdcb6a41c1a3a26976961b9b
Reference: blender/blender#68684
