invoke_props_dialog ignores height #68749
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
5 Participants
Reference: blender/blender-addons#68749
Operating system: MacOS Mojave 10.14.4
Graphics card: None
Broken: Version 2.80 (2.80 2019-07-29)
invoke_props_dialog ignores passed height of window
Create operator with invoke method:
Result:
Dialog window is opened with width 500 and low height
Expected
Dialog window is opened with width 500 and height 500.
Added subscriber: @sheerun
Added subscribers: @ideasman42, @JacquesLucke
Hmm, not sure if the height is actually ever used. The height of things is probably always determined by the content. Not sure why there is a height parameter.
@ideasman42 should the height parameter do something currently?
@sheerun, can you provide a small script that we can just copy into the text editor to test this bug, please?
Looked into it, while the height is used internally, the
UI_block_bounds_set_popup
call causes the height to be ignored.Using the height could be used to add padding to the dialog but don't see this as being useful.
Unfortunately removing this argument will break scripts.
Unless there is a good reason to support empty space, I think this argument could be deprecated.
Thanks for looking into it. I'm fine with deprecating the argument.
This issue was referenced by blender/blender@e64166652b
Added subscriber: @Jeroen-Bakker
the
width
andheight
are set inrna_generic_op_invoke
when theWM_GEN_INVOKE_SIZE
option is set.WM_GEN_INVOKE_SIZE
is used forinvoke_props_dialog
andinvoke_popup
. In our add-ons onlycreate prim
uses the height option. Both ignore the height option.Changed status from 'Confirmed' to: 'Resolved'
