Transparency visual artifacts on overlapping objects #68956
Reference: blender/blender#68956
Operating system: Windows 10 1903
Graphics card: 1080
Broken: 2.80 release
When a transparent object is curved and thus can visually "overlap", the overlapping area becomes glitchy in the viewport (both lookdev and Eevee, but not Cycles):
Open attached file and rotate around the mesh.
transparency.blend
Added subscriber: @RobertS
Transparency visual artifacts in lookdev modeto Transparency visual artifacts on overlapping objectsAdded subscriber: @dark999
You forgot to upload file generated form
Help > Save Sysyem Info
, however with your file i have this result in Lock Dev, Eevee and Cycles rendered viewport on linux Blender 2.80f6cb5f5449
(Stable) AMD FX8350, 16GB DDR3, GTX690 2+2 GB VRam- Nvidia drivers 435.17 an latestdailybuild Blender 2.81Alpha (2019-08-21)The operating system, main memory size, GPU brand and model, GPU driver version and Blender hash or its build date may be needed by developers to investigate this issue
Check if the hardware and operating system have the latest update installed and if they are working properly outside of Blender
Update your GPU drivers from Nvidia support site can solve/mitigate this problem
thank you
Added subscribers: @fclem, @lichtwerk
Looks like typical sorting problem with Alpha Blend mode? See https://docs.blender.org/manual/en/dev/render/eevee/materials/settings.html#sorting-problem
If you dont need real lighting in your shader you can use the Transparent BSDF node, that suffers from the same sorting problem internally, but is not noticable.
Sorry @fclem for asking once again: This can be closed, right?
Yes this is general alpha sorting issue.
