Look-dev volume shader glitch (zero scale object volume) #69070
Closed
opened 2019-08-23 02:18:58 +02:00 by Zach Hixson · 6 comments
Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 417.35
Broken: version: 2.80 (sub 75), branch: master, commit date: 2019-07-29 14:47, hash: f6cb5f5449
When using look-dev mode, I have found that if you have an object which has a volume scatter shader applied to it, who's size gets animated to "0" the entire screen fills with that volume effect IE: You stop being able to see anything because the air is now a thick smoke and it's all just a solid color.
  1. Create the main object to animate, as well as a cube or something simple so that we can observe the bug
  2. On the main object, apply a material that uses the "volume scatter," shader. All settings can be left at default.
  3. animate the scale of the main object to go from 1 -> 0.
  4. The frame which the object hits zero, the screen fills up entirely with the volume and you can no longer see the rest of the scene.
below is a screenshot and a sample file where I was able to reproduce the bug.
bugged.blend
**System Information** Operating system: Windows-10-10.0.18362 64 Bits Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 417.35 **Blender Version** Broken: version: 2.80 (sub 75), branch: master, commit date: 2019-07-29 14:47, hash: `f6cb5f5449` **Short description of error** When using look-dev mode, I have found that if you have an object which has a volume scatter shader applied to it, who's size gets animated to "0" the entire screen fills with that volume effect IE: You stop being able to see anything because the air is now a thick smoke and it's all just a solid color. **Exact steps for others to reproduce the error** 1. Create the main object to animate, as well as a cube or something simple so that we can observe the bug 2. On the main object, apply a material that uses the "volume scatter," shader. All settings can be left at default. 3. animate the scale of the main object to go from 1 -> 0. 4. The frame which the object hits zero, the screen fills up entirely with the volume and you can no longer see the rest of the scene. below is a screenshot and a sample file where I was able to reproduce the bug. ![example.png](https://archive.blender.org/developer/F7690171/example.png) [bugged.blend](https://archive.blender.org/developer/F7690173/bugged.blend)
Author
Added subscriber: @ZachHixson
Added subscriber: @Jaxxtrend
Member
Added subscriber: @lichtwerk
Member
There are usually better ways than scaling to zero, but can confirm, this shouldnt happen.
Philipp Oeser changed title from Look-dev volume shader glitch to Look-dev volume shader glitch (zero scale object volume) 2019-08-29 12:34:22 +02:00
This issue was referenced by 0366c46ec6
This issue was referenced by 0366c46ec64e42135953aad1de41c6976947e7a4
Clément Foucault self-assigned this 2020-01-27 19:53:03 +01:00
5 Participants
Reference: blender/blender#69070
