Collada export, does not take "diffuse" value from material's 'base color' when nodes are disabled #69090
Reference: blender/blender#69090
Operating system: WIN 10
Graphics card: Quadro P1000
Broken: 2.80 (sub 75), branch: master, commit date: 2019-07-29 14:47, hash:
f6cb5f5449
, type:build date: 2019-07-29, 09:44 AM
Worked: 2.79b
Assigning a material with color directly to faces in 2.80 and exporting it as a .DAE (Collada) works fine.
Assigning a material with color from a library (Material Library VX add-on) and exporting the file as a .DAE (Collada) doesn't work. The color doesn't get assigned to the "diffuse" property.
I apologize if I'm repeating a known bug (I did try to search). I am also not a programmer and am using Blender for the first time, so pardon any mistakes in nomenclature or process...
Here is a .Blend file of a cube colored with a material created from scratch:
Direct_red.blend
Here is a .Blend file of a cube colored with a material from a library (I hope the file contains the info?):
Library_red.blend
Added subscriber: @ggagnon
I can reproduce the issue. The issue is probably that only the node tree is evaluated to figure out the diffuse color. In the second file, the node tree has not been created yet. For me it works after I clicked on "Use Nodes".
@ggagnon can you confirm that this is the issue you describe?
I am not entirely sure what you are asking, so I tried:
Assigned a material library color to the default cube and exported to .DAE. Then I re-imported the DAE, clicked on 'use nodes' and the color is still not correct.
Assigned a material library color to the default cube when 'use node' (I think this actually turns it off (bar goes grey) is selected and exported to .DAE. Then I re-imported the DAE and the color is still not correct, regardless of whether I click on 'use nodes' or not.
library_red.blend
.Use Nodes
in the material panel as shown in the screenshot above.In my case, the newly imported cube is red.
Maybe I understand the problem incorrectly,
OK!
At which point, I would export to Collada and never think to go turn what was ON and turned itself OFF, back to ON. Not that I even knew "Use Nodes" was an option before submitting this ticket. I'm completely new to Blender.
Now, our CAD software outputs .STL files, which we have to painstakingly paint in Blender and save as Collada (.DAE) because Collada files actually save color info, where .STL files do not.
So I have to ask, what is the point of EVER allowing Collada files to save without the color info, ie: with "Use Nodes" turned OFF?
That being said, I suspect that our Material Library file just needs to be saved with "Use Nodes" turned on? This material library file was created in Blender 2.79b and I had the misfortune of trying to use it in Blender 2.8. I will try it.
That is a bug, actually. I was just making sure that we are talking about the same thing.
If "Use Nodes" is disabled, the written color information should be taken from the object color.
Hmm..
I open my material library file with Blender 2.8, located at:
C:\Program Files\Blender Foundation\Blender\2.80\scripts\addons\materials_library_vx\
"Use Nodes" is turned OFF (as expected, from above).
I turn "Use Nodes" ON and then try to save under a different file name.
Blender crashes...ICOR_1.1.blend
The attached file is the Material Library created under Blender 2.79b
Oh, OK. Sorry for the passive aggression.
Collada export, "diffuse" not being assigned color when material assigned from a libraryto Collada export, does not take "diffuse" value from material's 'base color' when nodes are disabledThis issue was referenced by
8fc68a2e9c
