Driver not following scale #69112
1 Participants
Reference: blender/blender#69112
I was trying to redo the ik/fk switch for my character rig so I can make the animations more easier, but now I'm in this situation where the driver doesn't follow the applied scale of the armature. So instead of following the frames I set to change the value of the driver, the value gets multiplied 100 times
Go to the scene tab, set the unit scale to 0.01, use metric.
Now scale up the armature to 100 and apply the scale.
Now add a driver to a bone, and make that driver change the value from the location, rotation or scale from the bone you want it to follow. Make sure you use average value cause I don't know if happens for the other types
Boom, the values get multiplied by 100.
Has this ever happened to anyone else? if so, what is the fix for it?
Added subscriber: @Maker26
and just in case you can't understand what I am talking about, here's a blend file that I manage to give it a similar problem to this one.
DriverTest.blend
The problem is now fixed, I had to use scripted expression instead in order to get the driver value correctly. var/# is what fixed my issue.
Topic is now solved
