Straightforward boolean operations produce non-manifold meshes (missing faces) #69150
6 Participants
Reference: blender/blender#69150
Operating system: Mac OS X 10.14.6
Graphics card: irrelevant
2.80 and 2.81 development build 2019-08-26. Also reproducible in 2.79.
Boolean operations will sometimes produce non-manifold errors like missing faces, even if all meshes involved are manifold and share no common vertices, faces, nor edges.
ClapperSlate-dualMaterial.blend
Clapper Slate-black
andClapper Slate-white
meshes.Select, Select All By Trait, Non Manifold
).Clapper Slate-black
, the ‘D’ in ‘DIRECTOR’ is missing its bottom faces. InClapper Slate-white
, the ‘P’ in ‘PRODUCTION’ is missing its top faces.All meshes used in these boolean modifiers are manifold and have neither duplicate points or edges, nor degenerate geometry. There are no shared points, edges, or faces. These operations should just work.
(For completeness, the attached file is based on https:*www.thingiverse.com/thing:1463739 and will be published as https:*www.thingiverse.com/thing:3828610)
Added subscriber: @DrLex
#72074 was marked as duplicate of this issue
Added subscriber: @AbidMaqbool
Can't understand the problem.
Can you more clarify prob by capturing onscreen video, or point out by pictorial way.
Please try, Blender 2.81 too https://builder.blender.org/download/
The latest 2.81 development build exhibits the same problem. I have also tried this in 2.79, and it has the problem too.
These are the minimal detailed instructions to demonstrate the problem, because making these instructions costs a lot of time.
Clapper Slate-white
which is already selected.Clapper Slate-black
object by clicking its name at the top right of the window.Clapper Slate-black
.Select
menu, chooseNone
to ensure no points are selected. You can also do this with the alt-A keyboard shortcut.Select
menu, chooseSelect All By Trait
, thenNon Manifold
.Result: if the Boolean operators would work correctly, no points must be selected in step 8. However, points are being selected. This means the model has non-manifold errors. These errors can only be caused by a flaw in the implementation of the Boolean operators because of the reasons explained in the original post. If you don't know what “non-manifold” means or why it is an error, please escalate this to someone who does.
In Solid View mode, it can be seen that the error is due to two faces missing in the letter “D,” in other words there is a hole in the object. This can also be seen in the
Clapper Slate-white
object by repeating steps 6 to 8 after going back to Object Mode and selecting that object.Problems like these will cause ugly defects during rendering, and it also make it a pain to export models for use in other programs, so please don't try to dismiss this by saying it can be fixed by means of some workaround to fill the holes. The holes must not be there in the first place. Other programs have no problem with boolean operations like these. I see no reason why Blender would be allowed to have problems.
Added subscriber: @lichtwerk
Can confirm.
This is a hard one to track down [havent found the root cause yet, assume this is a combination of different things].
Most likely, this is a duplicate of #54406 (Boolean Union Bug), as also in this case, translating either participating objects just slightly will resolve...
Anyhow, booleans are a subject of a complete rewrite, there is close to no chance this will get fixed on the current code, so will merge this into #54406...
Closed as duplicate of #54406
Added subscriber: @ajlanaltug
Added subscriber: @jimqode
I can confirm this problem still exists with 2.83.1
Sculpting seperate parts then trying to merge them into one object for 3d printing is very painful because of this bug.
Added subscriber: @CMC
Does it still exist in 2.83.3? That is the latest version atm.
