Dimensions affects scale settings - shouldn't #69254
Reference: blender/blender#69254
Operating system: Mac 10.12.6
Graphics card:
Broken: 2.8
Setting precise dimensions in dimension panel affects scale set to object - breaks bevel (and other) functionality.
broken dimensions.blend
Create a cube of a certain size. I'm trying to make a tabletop, so I'm making the cube 72". Use the Dimensions panel to set the other 2 dimensions to the correct size (in my case, x:72" y:48" z:2"). Scale changes to x:1 y:.667 and z:.028. Scale should remain as 1 in all axes and dimension should set values independently.
Otherwise, things like the bevel tool or modifier act as if the mesh is distorted, which doesn't allow you to add an even bevel.
I'm a new Blender user (use C4D mostly, but have used Wavefront, Electric Image, TDI, Lightwave, etc.) so I may be confused here, but dimensions should reset the scale (or keep it) at 1/1/1 in order to have the tools operate properly on the mesh. Otherwise Dimensions is just another way to scale the object (which is less useful).
Thanks.
Added subscriber: @jpburns
Added subscriber: @AbidMaqbool
Not a bugs though...
In Blender Dimension & Scales both effects proportionally when you modify one of them
Latter (when you really need it e.g. before using modifiers) you can apply scales which sets the scale back to 1 (same for all transforms)
In
Viewport
press Ctrl + A to access menu:or
Note: For community supports best place: https:*blender.community/c/ e.g. https:*blender.chat/channel/support
Added subscriber: @WilliamReynish
This is basically asking for parametric objects in Blender. We don't have that built-in, and it's sorely missing, but it's not a bug.
