Some lines in .pot-files don't translate to any language #69307
Closed
opened 2019-08-29 17:35:29 +02:00 by Matthias Richter · 6 comments
Some strings in .pot-files are not affected/translated when building the manual. This includes every language.
List of .pot-files with this issue:
getting_started\about\history.pot --- last line ("A totally redesigned UI for easier navigation...")
getting_started\installing\macos.pot --- line 4 ("Stable releases of Blender for macOS...")
getting_started\installing\macos.pot --- line 7 ("How to make a portable installation")
getting_started\installing\windows.pot --- line 10 ("How to make a portable installation")
Some strings in .pot-files are not affected/translated when building the manual. This includes every language. List of .pot-files with this issue: getting_started\about\history.pot --- last line ("A totally redesigned UI for easier navigation...") getting_started\installing\macos.pot --- line 4 ("Stable releases of Blender for macOS...") getting_started\installing\macos.pot --- line 7 ("How to make a portable installation") getting_started\installing\windows.pot --- line 10 ("How to make a portable installation")
Author
Member
Added subscriber: @trans-later
Matthias Richter changed title from Last line in getting_started/about/history doesn't translate to any language to Some lines in .pot-files don't translate to any language 2019-08-29 19:38:19 +02:00
Author
Member
I think this is due to a wrong placement of the caption after ".. tip::" and ".. rubric::" in the corresponding .rst-files. I don't have commit permissions for subversion, so I can't change that.
Member
Added subscriber: @Blendify
Member
Might be related to #55545. @trans-later I have given you commit access so you can commit your language patches and optionally look into this. If we do find the reason behind these issues we need to report them to the upstream project so it can be fixed.
https://github.com/sphinx-doc/sphinx-intl
Might be related to #55545. @trans-later I have given you commit access so you can commit your language patches and optionally look into this. If we do find the reason behind these issues we need to report them to the upstream project so it can be fixed. https://github.com/sphinx-doc/sphinx-intl
Author
Member
Hi,
I don't know what exactly caused this behaviour, but I found a solution:
If you rebuild the pot-file from the corresponding rst-file (I used "make update_po" for this) and use it to create a new po-file, everything works fine. You'll have to manually copy all translated messages to the new po-file though.
Hi, I don't know what exactly caused this behaviour, but I found a solution: If you rebuild the pot-file from the corresponding rst-file (I used "make update_po" for this) and use it to create a new po-file, everything works fine. You'll have to manually copy all translated messages to the new po-file though.
Member
Closed as duplicate of #55545
2 Participants
Reference: blender/blender-manual#69307
