Particle Info data not processing #69370
5 Participants
Reference: blender/blender#69370
Operating system: Ubuntu 19.04
Graphics card: Nvidia Asus RTX 2080ti
Broken: (blender-2.80-linux-glibc217-x86_64)
While using a smoke simulation within the particle system, the domain material cannot factor the particle age/lifetime
Create a smoke simulation
Create a particle system
Use particle system as source of smoke
Add a principled volume shader to domain
Try and use particle info such as age/lifetime to control the brightness emission from shader.
(more or less)
I have been at this for a couple of days and I simply cannot get the particles age/lifetime to factor the brightness of emission.
This is for a cloud simulation, if this bug cannot be fixed is there any suggestion in how to make the particle "fade in", using the life time or age on the density would also work to fade in however the particle data seems to be lost somewhere.
Added subscriber: @breebee-4
Added subscriber: @StephenSwaney
It would be nice to have a .blend so we can see exactly what you are doing.
breesmoke54.blend
Thank you for the quick response, here is the blend. You will notice in the animation of the particle/smoke that each particle is born instantly with full emission giving the "glitchy" effect. I have been trying to find a way to use the age/lifetime particle data to "fade in" each particle either with the emission or density or a transparency shader with the particle data as a factor. Essentially the opposite effect that the "dissolve" parameter has on the particles. You can see from frame 1 of the animation to frame 2
Here is a more clear example of the data being null. In the first picture you can see (age * 0 = 0) then the second picture (age * 500 = 0) then in the third picture you can see (age + 500 = 500 density).
first
second
third
No one is looking into this after almost a week? Come on guys, let me know if I need to make a direct payment for someone.
Added subscriber: @jenkm
I guess you're trying to use the Particle Info node for something other than its intended purpose.
https://docs.blender.org/manual/en/2.80/render/shader_nodes/input/particle_info.html
Thank you for the response Yevgeny it is truly appreciated. The info node should output a float or integer for age/lifetime and I am just doing math so it should be working from that perspective. In any case it should be verified atleast to be a bug or not, that is important. The only way to control the brightness/density over time of the smoke is with the particle age/lifetime.
Someone I am trying to hire says its an issue with eevee particle node, can a developer please just look and confirm? It would truly be appreciated to get some information.
The Particle Info node can be used in the material node tree for objects that are used as the Dupli Objects, when you use Object or Group render mode of a Particle System...
The Particle Info node works with Cycles but is not supported for EEVEE.
https://docs.blender.org/manual/en/2.80/render/eevee/materials/nodes_support.html
Added subscriber: @lichtwerk
Thanks @jenkm for checking.
If this is just about Eevee + Particle Info Node, then yes, this is not supported.
Afraid we have to close this, thx for the report anyways...
Added subscriber: @ChristophWerner
So there's not yet possible to fade out particles in eevee?
I'm working with 2.93LTS.
