The Object Mode drop down menu in the 3D viewports is not reactive to larger font point settings. #69544
Open
opened 2019-09-05 16:21:24 +02:00 by Jeff Hanna · 13 comments
Operating system: Windows 10 1803
Graphics card: nVidia RTX 2070
Broken: v 2.80 as found on the splash screen
The Object Mode drop down menu in the 3D viewports does not properly resize itself if the user picks a larger font point size in the Themes section of the preferences. Instead of resizing the control truncates the overrunning text with a square character.
Start Blender
In Preferences \Themes \ Text Style change the Widget Points setting from the default of 11 to a larger value. I used 15.
**System Information** Operating system: Windows 10 1803 Graphics card: nVidia RTX 2070 **Blender Version** Broken: v 2.80 as found on the splash screen The Object Mode drop down menu in the 3D viewports does not properly resize itself if the user picks a larger font point size in the Themes section of the preferences. Instead of resizing the control truncates the overrunning text with a square character. **Exact steps for others to reproduce the error** Start Blender In Preferences \Themes \ Text Style change the Widget Points setting from the default of 11 to a larger value. I used 15. ![Object_Mode_Text_Truncated.png](https://archive.blender.org/developer/F7718346/Object_Mode_Text_Truncated.png)
Author
Added subscriber: @jeff_hanna
#72065 was marked as duplicate of this issue
Added subscriber: @mano-wii
I could not reproduce the problem.
In my case appears .. which seems to be a reasonable way to indicate that there is more text in front.
Can you better describe how you got that result?
I could not reproduce the problem. In my case appears `..` which seems to be a reasonable way to indicate that there is more text in front. ![Sem título.png](https://archive.blender.org/developer/F7826307/Sem_título.png) Can you better describe how you got that result?
Author
Sure. I changed the UI font to Segoe UI, as I'm on Windows and I find that font easier to read (50 year old eyes). I raised the font size to make everything a bit easier for me to resolve on my 35" 2560 x 1440 monitor. I was hoping the mode dropdown would resize horizontally to fit the full string "Object Mode", but the UI is not that dynamic. It would be nice if it was.
Member
Added subscribers: @WilliamReynish, @lichtwerk
Member
Usually dropdown boxes scale with the widget font size.
However in this case, this is explicitly constrained to a fixed size, see https://developer.blender.org/diffusion/B/browse/master/release/scripts/startup/bl_ui/space_view3d.py$557
@WilliamReynish : any particular reason we are doing this? (if I scale the Widget Font size I see all sorts of enum dropdown scale happily with the font, I dont see why we need an exception here?)
Usually dropdown boxes scale with the widget font size. However in this case, this is explicitly constrained to a fixed size, see https://developer.blender.org/diffusion/B/browse/master/release/scripts/startup/bl_ui/space_view3d.py$557 @WilliamReynish : any particular reason we are doing this? (if I scale the Widget Font size I see all sorts of enum dropdown scale happily with the font, I dont see why we need an exception here?)
Added subscriber: @iss
Changed status from 'Needs Developer To Reproduce' to: 'Confirmed'
Can confirm this with SegoeUI font and scaled interface on multiple places.
Can confirm this with SegoeUI font and scaled interface on multiple places. ![1.png](https://archive.blender.org/developer/F8268819/1.png) ![2.png](https://archive.blender.org/developer/F8268821/2.png)
Member
Added subscriber: @Harley
Member
Note that the Segoe UI font, like almost all fonts, does have the “horizontal ellipsis” character that should be used for continuation character. But it, like many fonts, does not have the “two dot leader” character we are using for continuation, hence why you get that white block “tofu” character.
We are using this incorrect character just because the ellipsis in our default fonts is too wide. That character’s width is corrected in the following patch: https://developer.blender.org/D6055
Note that the Segoe UI font, like almost all fonts, does have the “horizontal ellipsis” character that should be used for continuation character. But it, like many fonts, does not have the “two dot leader” character we are using for continuation, hence why you get that white block “tofu” character. We are using this incorrect character just because the ellipsis in our default fonts is too wide. That character’s width is corrected in the following patch: https://developer.blender.org/D6055
Added subscriber: @mrvanes
Philipp Oeser removed the
label 2023-02-10 09:25:11 +01:00
6 Participants
Reference: blender/blender#69544
