Outliner doesn't update text data-block list and crashes on unlinking text
Broken: version: 2.81 (sub 8), branch: master, commit date: 2019-09-06 22:44, hash: rBed779333bb82
After setting up my workspace layout for text editing, I set the outliner's display mode to "Blender File" and the filter ID type to "Text". And when I add an empty text data-block in the text editor, the list of text data-blocks in the outliner doesn't update instantly unless you hover anywhere on it's header. And when I tried to unlink the text data-block, it just crashes instantly.
  1. In the outliner, set the display mode to "Blender file".
  2. Set the filter I.D. type to "Text".
  3. Click on the "New" button in the header of the text editor to open an empty text block.
  4. Hover over any part of the outliner's header.
  5. Click on the "Unlink" button to unlink the empty text block. [on the Text Editor header]
Related Objects
Chris Tabron (tetrapixel) renamed this task from Outliner list doesn't update text data-block list and crashes instantly after unlinking blank text data-block to Outliner doesn't update text data-block list and crashes instantly after unlinking blank text data-block.Sep 7 2019, 9:43 AM
Chris Tabron (tetrapixel) created this task.
Chris Tabron (tetrapixel) updated the task description. (Show Details)
Dalai Felinto (dfelinto) lowered the priority of this task from 90 to Low.Sep 18 2019, 2:21 AM
Confirmed. It should be a straightforward fix, and in a way it is the same solution for both:
  • A notifier/message when creating the text ID.
  • Tag outliner to redraw/free when deleting the text ID.
For the records the crash is:
//source/blender/editors/space_outliner/outliner_draw.c:3101
3101        if (ELEM(tselem->type, 0, TSE_LAYER_COLLECTION) && ID_IS_LINKED(tselem->id)) {
@Nathan Craddock (Zachman) can I interest you into looking at this?
Dalai Felinto (dfelinto) renamed this task from Outliner doesn't update text data-block list and crashes instantly after unlinking blank text data-block to Outliner doesn't update text data-block list and crashes on unlinking text.Sep 18 2019, 2:21 AM
Dalai Felinto (dfelinto) updated the task description. (Show Details)
Yes, I will take a look.
