Node Wrangler: search does not find "image sequence" and "multiple images" #70044
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#70044
Operating system: Darwin-18.7.0-x86_64-i386-64bit 64 Bits
Graphics card: Intel(R) Iris(TM) Graphics 540 Intel Inc. 4.1 INTEL-12.10.12
Broken: version: 2.80 and 2.81 (sub 11), branch: master, commit date: 2019-09-17 19:54, hash:
blender/blender@9609840b5e
Worked: unknown
In the shader node editor, searching for nodes does never show the "image sequence" and "multiple images" nodes.
Open shader node editor
Press shift-A
Click search
Search for "image", "sequence" or "multiple"
Only result: image texture when searching for image; others no result
Added subscriber: @blenderrocket
Added subscriber: @Jeroen-Bakker
There are no nodes called
Image Sequence
orMultiple Images
, so works as expected. With theImage Node
you can select an Image Sequence, but that is not an Node on its own.Added subscriber: @lichtwerk
Node Wrangler Addon has these, enable the Addon, should be there then...
Will close this report, but feel free to comment again if issues persist...
Thanks, sorry you are right, I hadn't realized these are part of node wrangler. I will report it there.
Changed status from 'Resolved' to: 'Open'
Hold on, I can reproduce, we can keep this report, will change it accodingly...
Shader node editor: search does not find "image sequence" and "multiple images"to Node Wrangler: search does not find "image sequence" and "multiple images"Changed status from 'Open' to: 'Archived'
Aaand a step back... sorry for the noise here.
Just boils down to more or less what @Jeroen-Bakker said.
NodeWrangler just uses
Image Texture
node(s) internally, it inserts a menu with operators into the node category menus, so no, these are not nodes that are found by the search...There might be a way to extend the search to also include menu entries (operators even) that were added by an Addon, this however would be a feature request which we dont handle here.
For requests, please visit: https://wiki.blender.org/wiki/Communication/Contact#User_Feedback_and_Requests
So will close again, sorry.
