Transform orientation shortcut wrong in documentation #70105
Eevee & Viewport
Rendering & Cycles
Needs Information from Developers
5 Participants
Reference: blender/blender-manual#70105
Operating system:
Graphics card:
Broken: (example: 2.80, edbf15d3c044, master, 2018-11-28, as found on the splash screen)
Hi, this shortcut doesnt work anymore : https://docs.blender.org/manual/en/latest/scene_layout/object/editing/transform/control/orientations.html
When I try to add it to the button, it returns an error:
AttributeError: 'Scene' object has no attribute 'type'
Added subscriber: @antonin.morlet
Which one is "this shortcut"?
It should be Alt+spacebar
Added subscriber: @lichtwerk
Shortcut is
now afaict.The bug assigning the other shortcut is blender/blender#65397 (Assigning shortcut to editor properties gives errors)
Will leave this report open for the documentation side only...
Transform orientation shortcutto Transform orientation shortcut wrong in documetationTransform orientation shortcut wrong in documetationto Transform orientation shortcut wrong in documentationThere is currently no shortcuts for the 2.7x keymap
This issue was referenced by 6024
