Weld Modifier Proposal #70240
23 Participants
Reference: blender/blender#70240
Motivation
While modifiers such as spin, mirror & array can merge duplicates, there are times when
Some modifier setups don't can't as easily predict duplicate geometry.
Examples include:
Lots of comments from users on
this thread .
Proposal
There will be two methods available:
(internally this will manipulate the
Mesh
structure without requiring it to be converted intoBMesh
).(this can use the existing merge-by-distance code)
Pros
Cons
Added subscriber: @ideasman42
Added subscriber: @howardt
Pointing out that some of the desire for this comes from the fact that the Bevel modifier can, as a result of clamping, put vertices on top of each other, and users would like them merged. As Campbell points out, the Bevel modifier itself could be changed to detect and merge in such cases. I would have done so if it were easy, but it is not so easy (the current code that merges nearby vertices gets quite complicated), so was delaying -- especially as my eventual goal is to get rid of clamping completely and continue beveling after such collisions cause merges.
All this is to say: restricting this to only happen at boundaries (seams) may not accomplish everything people want, so if possible that should be an option rather than a requirement,
Added subscriber: @Dspazio
@howardt wouldn't collapsing edges handle this case?
We should be able to support this as long as it doesn't result in faces using the same edge/vertex twice.
Collapsing edges would mostly handle that case, yes. I wasn't sure whether you intended to support that everywhere or just as part of handling merges across boundaries, but thinking about it, you must have meant the former, because the latter wouldn't come up in most cases, if ever.
One case that your Simple solution would rule out: cases where bevel acts as an inset into a particular face (because all edges around that face are beveled). At some point, the inner face of the inset disappears (always, for triangles; for regular polygons otherwise). Users would probably like that face to go away and all the points of the inner face to weld together. And a variant on this: sometimes the inner face degenerates into a line (e.g., insetting a rectangle).
Added subscriber: @cedriclepiller
I can add some others examples we talked about in the Bevel modifier thread.
One more from fiendish55
https://i.imgur.com/PfjPJ8K.gifv
Maybe it could be possible with modifiers (bevel, merge, triangulate on ngons) to achieve this kind of non-destructive beveling.
c043c82a09
.gifAdded subscriber: @Helo
Added subscriber: @Spatz
Added subscriber: @MatthewHeimlich
Please keep things like multires in mind during the design process. One of the best use cases that I can imagine for this kind of modifier is for sculptors who wish to split objects that should visibly be contiguous into multiple pieces so that they can really crank up the level of subdivision on each individual part for multires sculpting while still having them act like a single mesh for animation, edit mode, etc.
Added subscriber: @Josephbburg
I'm curious if this is planned to support joining objects, or only work on a single object? Sometimes in animation it would be nice to merge edges of objects together (hand/sleeve for example).
Added subscriber: @0rAngE
@Josephbburg it's possible although it wouldn't be a target for the first version of this patch.
Also, this feature seems better suited to a grouping than a single objects modifier - where all objects in the group have their seams welded.
Added subscriber: @ErickNyanduKabongo
I second this, If you guys can make it work, we will have a very powerful multires.
Added subscriber: @Ariel-Tavori
Added subscriber: @Tosky
The "full method" use the existing merge-by-distance code; it's right to say that will give us options like 'merge at first/last/3dcursor' and peraphs Empty? Because that could open new scenarios.
@Tosky, these don't make sense for modifiers since defining operations on individual vertices doesn't fit well with the current modifier stack.
Added subscriber: @BartekMoniewski
Added subscriber: @AnadinX
Added subscriber: @darrelljuk
Added subscriber: @MarcelLegindi
Hi,
Any update about this modifier for 2.82?
@cedriclepiller after 2.81 release.
Ok, thank you for your answer ;)
Added subscriber: @lemenicier_julien
Added subscriber: @item412
Added subscriber: @LapisSea
Added subscriber: @dupoxy
Added subscriber: @FrancoisRimasson
I wish to be able to collapse edge with no faces around (ie : edges used for sewing garments in the cloth modifier)
Added subscribers: @mano-wii, @brecht
@mano-wii, can you close this task and create a follow-up task for remaining improvements to the weld modifier, so we can consider this one finished for the release?
If there are still things to improve for 2.82, please create another task for that and tag it with the Blender 2.82 milestone.
As the main goal of this task (Weld Modifier Implementation) has already been resolved, closing.
Remaining proposals moved to #73139 (Weld Modifier Improvements).
