Marbling effect on Eevee and subsurface scattering... #70249
7 Participants
Reference: blender/blender#70249
Graphics card: GeForce GTX 1070 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 431.60
Broken: version: 2.81 (sub 12), branch: master, commit date: 2019-09-25 13:57, hash:
f8da7218be
Eevee backlight causes marbling light effects...with subsurface scattering
Created Suzanne model, added backlight. (included screen shot and test file)
SUZANNE_eevee_bklight.blend
Added subscriber: @Lteng
#69827 was marked as duplicate of this issue
I tested the version in 9-13-2019 as well and the marbling is also there. Not sure about earlier september versions.
I noticed also that changing the 'count' in the cascaded shadow map changes the marbling effect. (video capture included):
Blender_ [C__Users_Graphics 4_Downloads_Wip_SUZANNE_eevee_bklight.blend] 2019-09-25 08-57-47.mp4
Added subscribers: @fclem, @lichtwerk
This is due to
d8aaf25c23
.There are some things mentioned in D5659: Eevee: Shadow map refactor regarding SSS..
There is also more information here https://wiki.blender.org/wiki/Reference/Release_Notes/2.81/Eevee
That all being said, just opening your file in 2.81 after the shadow refactor will not give you the same results.
However, by tweaking some settings, you should be able to get comparable (if not better) results.
Soft Shadows
underProperties Editor
>Render Properties
>Shadows
(this was previously a per light setting)Properties Editor
>Render Properties
>Sampling
also helpsDont think this counts as a bug, but will let @fclem close...
Added subscriber: @jeacom
Bug or not, this is an undesirable behavior that makes SSS quality awful, to the point of unusable, this needs fix.
@jeacom : have you tried enabling
Soft Shadows
and setting Viewport Samples to 64 upwards?(this seems to have no marble artifacts for me -- can you show where this is still awful?)
I agree though that translucency looks different from before [distribution seems to be different, cannot be as soft as before?], maybe @fclem can comment on that...
Added subscriber: @SecuoyaEx
All those things may make it less noticeable but it doesn't solve it. More samples don't make it converge either.
Here's an example with with big radius, higher res shadows, soft shadows, lots of sss samples and viewport/render samples, high bitdepth, etc. Still visible
Crucially, if you turn off shadows for a particular light, SSS translucency will disappear.
There's at least one improvement. With VSM shadows in the past, the middle of things would get darker, like the ear. Now it's closer to Cycles. In any case, I think the line needs fixing, otherwise translucency is almost useless
@lichtwerk enabling soft shadows or upping samples only seems to smear out but not remove this weird line.
2048 samples, soft shadows enabled and the problem is still there:
Added subscriber: @bent
Thx for getting back now I actually get it better what is meant by 'marbling'.
Tbh, I am not sure what the origins of these are [or how to get rid of them], I think @fclem has to chime in here...
I am convinced that it was caused by D5659 might be some biasing issue.
It is caused by my refactor yes.
This is a side effect of having biased shadow maps. Before they were smoothed but I remove the smoothness properties.
A better ways would be to introduce a corrective bias to make it match perfectly the depth that is supposed to be in the shadow map.
This issue was referenced by
131ac2ec82
