Grease Pencil Canvas Grid Overlay Broken after DRW refactor #70399
Closed
opened 2019-09-30 20:05:45 +02:00 by Bun ny · 7 comments
Operating system: Windows 7 x64
Graphics card: NVIDIA GTX 580
Broken: ddb157999e
Worked: 2.80
The Canvas overlay isn't appearing at all, regardless of Mode and Overlay settings. This seems to have happened gradually after 2.80 release; a week or two ago (?) the Canvas started occasionally appearing at the wrong position and rotation, and in the last few days it's stopped appearing altogether.
Create new .blend, create new Grease Pencil object, open Overlay menu, toggle Canvas visibility.
**System Information** Operating system: Windows 7 x64 Graphics card: NVIDIA GTX 580 **Blender Version** Broken: ddb157999eed Worked: 2.80 **Short description of error** The Canvas overlay isn't appearing at all, regardless of Mode and Overlay settings. This seems to have happened gradually after 2.80 release; a week or two ago (?) the Canvas started occasionally appearing at the wrong position and rotation, and in the last few days it's stopped appearing altogether. **Exact steps for others to reproduce the error** Create new .blend, create new Grease Pencil object, open Overlay menu, toggle Canvas visibility.
Author
Added subscriber: @bunny
Antonio Vazquez self-assigned this 2019-10-01 22:53:26 +02:00
Antonio Vazquez removed their assignment 2019-10-01 23:22:43 +02:00
Clément Foucault was assigned by Antonio Vazquez 2019-10-01 23:22:43 +02:00
Added subscribers: @fclem, @antoniov
@fclem This was broken with the DRW refactor.
I have seen this fix partially the problem:
diff --git a/source/blender/draw/engines/gpencil/gpencil_engine.c b/source/blender/draw/engines/gpencil/gpencil_engine.c
index 10e9a79d143..397c1c58387 100644
--- a/source/blender/draw/engines/gpencil/gpencil_engine.c
+++ b/source/blender/draw/engines/gpencil/gpencil_engine.c
@@ -545,6 +545,7 @@ void GPENCIL_cache_init(void *vedata)
                                        DRW_STATE_WRITE_COLOR | DRW_STATE_BLEND_ALPHA |
                                            DRW_STATE_WRITE_DEPTH | DRW_STATE_DEPTH_ALWAYS);
       stl->g_data->shgrps_grid = DRW_shgroup_create(e_data.gpencil_line_sh, psl->grid_pass);
+      DRW_shgroup_uniform_mat4(stl->g_data->shgrps_grid, "gpModelMatrix", obact->obmat);
     /* blend layers pass */
But still there is problems if the mode is View mode.
@fclem This was broken with the DRW refactor. I have seen this fix partially the problem: ``` diff --git a/source/blender/draw/engines/gpencil/gpencil_engine.c b/source/blender/draw/engines/gpencil/gpencil_engine.c index 10e9a79d143..397c1c58387 100644 --- a/source/blender/draw/engines/gpencil/gpencil_engine.c +++ b/source/blender/draw/engines/gpencil/gpencil_engine.c @@ -545,6 +545,7 @@ void GPENCIL_cache_init(void *vedata) DRW_STATE_WRITE_COLOR | DRW_STATE_BLEND_ALPHA | DRW_STATE_WRITE_DEPTH | DRW_STATE_DEPTH_ALWAYS); stl->g_data->shgrps_grid = DRW_shgroup_create(e_data.gpencil_line_sh, psl->grid_pass); + DRW_shgroup_uniform_mat4(stl->g_data->shgrps_grid, "gpModelMatrix", obact->obmat); } /* blend layers pass */ ``` But still there is problems if the mode is View mode.
@fclem It looks this code in gpencil_engine.c is not working (at least is not passing the right matrix to shader group)
/* grid */
if ((v3d) && ((v3d->flag2 & V3D_HIDE_OVERLAYS) == 0) && (v3d->gp_flag & V3D_GP_SHOW_GRID) &&
(ob->type == OB_GPENCIL) && (ob == draw_ctx->obact) &&
((ts->gpencil_v3d_align & GP_PROJECT_DEPTH_VIEW) == 0) &&
((ts->gpencil_v3d_align & GP_PROJECT_DEPTH_STROKE) == 0)) {
  stl->g_data->batch_grid = gpencil_get_grid(ob);
  /* define grid orientation */
  switch (ts->gp_sculpt.lock_axis) {
    case GP_LOCKAXIS_VIEW: {
      /* align always to view */
      invert_m4_m4(grid_matrix, draw_ctx->rv3d->viewmat);
      /* copy ob location */
      copy_v3_v3(grid_matrix- [x], ob->obmat[3]);
      break;
    case GP_LOCKAXIS_CURSOR: {
      float scale- [x] = {1.0f, 1.0f, 1.0f};
      loc_eul_size_to_mat4(grid_matrix, cursor->location, cursor->rotation_euler, scale);
      break;
    default: {
      copy_m4_m4(grid_matrix, ob->obmat);
      break;
  /* Move the origin to Object or Cursor */
  if (ts->gpencil_v3d_align & GP_PROJECT_CURSOR) {
    copy_v3_v3(grid_matrix- [x], cursor->location);
  else {
  DRW_shgroup_call_obmat(stl->g_data->shgrps_grid, stl->g_data->batch_grid, grid_matrix);
@fclem It looks this code in `gpencil_engine.c` is not working (at least is not passing the right matrix to shader group) > /* grid */ > if ((v3d) && ((v3d->flag2 & V3D_HIDE_OVERLAYS) == 0) && (v3d->gp_flag & V3D_GP_SHOW_GRID) && > (ob->type == OB_GPENCIL) && (ob == draw_ctx->obact) && > ((ts->gpencil_v3d_align & GP_PROJECT_DEPTH_VIEW) == 0) && > ((ts->gpencil_v3d_align & GP_PROJECT_DEPTH_STROKE) == 0)) { > > stl->g_data->batch_grid = gpencil_get_grid(ob); > > /* define grid orientation */ > switch (ts->gp_sculpt.lock_axis) { > case GP_LOCKAXIS_VIEW: { > /* align always to view */ > invert_m4_m4(grid_matrix, draw_ctx->rv3d->viewmat); > /* copy ob location */ > copy_v3_v3(grid_matrix- [x], ob->obmat[3]); > break; > } > case GP_LOCKAXIS_CURSOR: { > float scale- [x] = {1.0f, 1.0f, 1.0f}; > loc_eul_size_to_mat4(grid_matrix, cursor->location, cursor->rotation_euler, scale); > break; > } > default: { > copy_m4_m4(grid_matrix, ob->obmat); > break; > } > } > > /* Move the origin to Object or Cursor */ > if (ts->gpencil_v3d_align & GP_PROJECT_CURSOR) { > copy_v3_v3(grid_matrix- [x], cursor->location); > } > else { > copy_v3_v3(grid_matrix- [x], ob->obmat[3]); > } > > DRW_shgroup_call_obmat(stl->g_data->shgrps_grid, stl->g_data->batch_grid, grid_matrix); > } > }
Antonio Vazquez changed title from Grease Pencil Canvas Overlay Broken in Windows 7 to Grease Pencil Canvas Grid Overlay Broken after DRW refactor 2019-10-02 08:24:12 +02:00
@fclem proposed fix: D5966
@fclem proposed fix: [D5966](https://archive.blender.org/developer/D5966)
Clément Foucault was unassigned by Antonio Vazquez 2019-10-02 15:15:14 +02:00
Antonio Vazquez self-assigned this 2019-10-02 15:15:14 +02:00
This issue was referenced by ddd40985e7
This issue was referenced by ddd40985e7dfe026323dede900fa2417fde225c0
Reference: blender/blender#70399
