Plane plus Modifier "skin" CRASH #70461
Reference: blender/blender#70461
Operating system: Windows 10
Graphics card: AMD 980 TI
Broken: (example: 2.80
Created a plane
Added Modifier "Subdivision Surface" "Veiwport " increased to 3
"Loop cut" through hot key
added 1 cut
moved division line up to create a Pringle type shape
Added modifier "Skin"
PROGRAM CRASH with no recovery.
Added subscriber: @Enlightened_Ape
Thanks for the great program. 2.8 is amazing!
Added subscriber: @dark999
i try to follow step to reproduce this crash, however i not have crash on linux Blender 2.80
f6cb5f5449
(Stable) AMD FX8350, 16GB DDR3, GTX690 2+2 GB VRam- Nvidia drivers 435.21, Factory Setting applied#70461-pringle01.blend
i not understand why add skin instead solidify modifier to make a solid chips
Next time you want report a bug you can use
Help > Report a Bug
item andstrictly
compile following proposed form, all text from[
to]
must be edited. You must clearly describe steps to reproduce issue and attach a simplest possible .blend file as requestAdded subscriber: @brecht
Indeed, we need a .blend file with an object that will crash when a skin modifier is applied to it.
Added subscriber: @mont29
