principled shader alpha bleeding issues in Eevee #70586
Closed
opened 2019-10-06 15:21:58 +02:00 by MACHIN3 · 10 comments
Operating system: Linux-4.13.10-041310-generic-x86_64-with-debian-stretch-sid 64 Bits
Graphics card: GeForce GTX 1050/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 390.67
Broken: version: 2.81 (sub 13), branch: master, commit date: 2019-10-04 22:33, hash: ab519b91b2
Worked: 2.80 stable
This is maybe related to this issue reported in May.
The issue presents itself as what looks like black bleeding in, when using the alpha socket of the principled pbr shader. Curiously, it only happens when either the Subsurface, Clearcoat or Transmission sockets are connected, and even if they feed in a value of 0.
The issue does not seem to be related to the interpolation used of the alpha texture. Neither is there any actual black color present- for instance in a color map - that could be bleeding in from the outside.
The issue is not present in the 2.80 stable release.
It can be avoided by mixing with a transparent shader instead, but I was hoping that would be a thing of the past now.
video demo
principled_shader_alpha_bleeding_issues.zip
  • open the blend contained in the above zip file in a (recent?) 2.81 build
  • the Y-facing circle and 'Access Electrical' decal display a dark outline at the alpha border
    • mute or disconnect all the 3 value inputs, the bleeding vanishes
    • unmute or reconnect any of the 3, and it comes back
  • the X-facing decals don't have that issue, the transparency is craeted by mixing a transparent shader
  • load the blend in 2.80, and everything should look fine
**System Information** Operating system: Linux-4.13.10-041310-generic-x86_64-with-debian-stretch-sid 64 Bits Graphics card: GeForce GTX 1050/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 390.67 **Blender Version** Broken: version: 2.81 (sub 13), branch: master, commit date: 2019-10-04 22:33, hash: `ab519b91b2` Worked: 2.80 stable **Short description of error** This is maybe related to [this issue ](https://developer.blender.org/T64883) reported in May. The issue presents itself as what looks like black bleeding in, when using the alpha socket of the principled pbr shader. Curiously, it only happens when either the Subsurface, Clearcoat or Transmission sockets are connected, and even if they feed in a value of 0. The issue does not seem to be related to the interpolation used of the alpha texture. Neither is there any actual black color present- for instance in a color map - that could be bleeding in from the outside. The issue is not present in the 2.80 stable release. It can be avoided by mixing with a transparent shader instead, but I was hoping that would be a thing of the past now. ![alpha_bleeding.png](https://archive.blender.org/developer/F7792740/alpha_bleeding.png) ![no_bleeding_when_mixing_transparent_shader.png](https://archive.blender.org/developer/F7792742/no_bleeding_when_mixing_transparent_shader.png) [video demo ](https://www.youtube.com/watch?v=Ss78eBp3JZQ) [principled_shader_alpha_bleeding_issues.zip](https://archive.blender.org/developer/F7792733/principled_shader_alpha_bleeding_issues.zip) **Exact steps for others to reproduce the error** * open the blend contained in the above zip file in a (recent?) 2.81 build * the Y-facing circle and 'Access Electrical' decal display a dark outline at the alpha border * mute or disconnect all the 3 value inputs, the bleeding vanishes * unmute or reconnect any of the 3, and it comes back * the X-facing decals don't have that issue, the transparency is craeted by mixing a transparent shader * load the blend in 2.80, and everything should look fine
Author
Added subscriber: @MACHIN3
Author
I've tested in the oldest 2.81 build I still had - cb7ead2e3b from August 15th - and it's already present there. So it doesn't look like a recent change caused this.
I've tested in the oldest 2.81 build I still had - cb7ead2e3b62 from August 15th - and it's already present there. So it doesn't look like a recent change caused this.
MACHIN3 changed title from principled shader alpha bleeding issues to principled shader alpha bleeding issues in Eevee 2019-10-06 15:30:26 +02:00
Added subscriber: @Pinnhead
I have the same issues with Y-facing circle in blender-2.81-54a9649e2636-windows64
Added subscriber: @MarcClintDion
Windows 10 Home (Auto Update)
GTX 1070 (Version: 26.21.14.3086)
The issue wasn't present for the July 30th build but is present for the Aug 20 build as shown in the following two images. (The splash screens are included for the date and hash)
Windows 10 Home (Auto Update) GTX 1070 (Version: 26.21.14.3086) The issue wasn't present for the July 30th build but is present for the Aug 20 build as shown in the following two images. (The splash screens are included for the date and hash) ![2019-07-30.png](https://archive.blender.org/developer/F7794743/2019-07-30.png) ![2018-08-20.png](https://archive.blender.org/developer/F7794744/2018-08-20.png)
Clément Foucault self-assigned this 2019-10-08 12:38:57 +02:00
This issue was referenced by 576c782b11
This issue was referenced by 576c782b11f629130b1226f37d4fd467f8793247
Author
Thanks, it's working great now. As long as the material is using Alpha Blend. In Alpha Hashed the issue returns. Not sure if that is just unavoidable, or if it's an oversight.
alpha_mapping_issues_alpha_blend_vs_hashed.blend
Thanks, it's working great now. As long as the material is using Alpha Blend. In Alpha Hashed the issue returns. Not sure if that is just unavoidable, or if it's an oversight. ![alpha_blend.png](https://archive.blender.org/developer/F7798699/alpha_blend.png) ![alpha_hashed.png](https://archive.blender.org/developer/F7798701/alpha_hashed.png) [alpha_mapping_issues_alpha_blend_vs_hashed.blend](https://archive.blender.org/developer/F7798698/alpha_mapping_issues_alpha_blend_vs_hashed.blend)
The alpha hashed issue has been reported already #70640. It's slightly different but I know a fix.
5 Participants
Reference: blender/blender#70586
