Texture won't display or won't do correctly on eevee when used as bump and other input #70614
Reference: blender/blender#70614
Graphics card: GeForce GT 555M/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 391.35
Broken: version: 2.81 (sub 14), branch: master, commit date: 2019-10-05 20:51, hash:
4707f1982d
Texture won't display or won't do correctly on eevee when used as bump and other input.
If I connect it only to normal, with a bump node between it works fine, but if I use that same texture to also drive the albedo, either connecting it directly or throught some nodes it won't work, affecting only the albedo.
If I use that same texture as a roughness and bump map, it will display correctly as roughness but not for the normal input.
Workaround is duplicating that same texture (shift + D).bug_tank.blend
Plug a texture output in two different inputs of a principled material. bug_tank.blend
{F7794994}attached .blend file
EDIT: I sent a version without the image packed and don't know how to delete the older version without it, so the bigger one is the right file to open.
Added subscriber: @xdanic
#70611 was marked as duplicate of this issue
Added subscriber: @lichtwerk
Can confirm, checking... (assume this is caused by
ffd5e1e6ac
)Actually caused by 5c79f2d0fb...
@fclem: havent done performance checks, not sure if this defeats the purpose of backwards iter [could even be worse!], but if we check if the links are actually the same, we can fix by P1133
(couldnt find a quick check on a socket to see if it has more than one link...)
note:
nodeCountSocketLinks
could be used in P1133 [still not sure if that defeats the purpose / kills performance]Added subscribers: @SpectreFirst, @fclem, @EAW, @Likkez-2, @mano-wii, @NahuelBelich
This issue was referenced by
f61a8a2abd
