Fillet and chamfer option is missing in belnder 2.81 experimental #70705
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
6 Participants
Reference: blender/blender-addons#70705
This option is available in blender 2.80 when curve is switched to edit node . This option is available with right click in edit mode. But this is not available in blender 2.81 experimental. This is very useful.
{F7801606, size = full}
Added subscriber: @tsandeep156
Fillet option is available in blender 2.80 when curve is switched to edit node . This option is available with right click in edit mode. But this is not available in blender 2.81 experimental. This is very useful
Added subscriber: @mano-wii
Are you referring to the
Add Curve: Extra Objects
addon?Added subscriber: @lichtwerk
Are you sure this is not added by an [external] Addon in 2.80 (that hasnt been enabled/installed in 2.81)?
Try if you also have this functionality in 2.80 with File → Defaults → Load Factory Settings as well.
Added subscriber: @dark999
Add Curve Extra Object
addons add this feature on 2.80 was usable from menu, in 2.81alpha is moved in side panelAdded subscriber: @SpectreFirst
Added subscriber: @cwolf3d
Fillet and Chamfer were in Add Curve: Extra Objects. Now they have moved to the Curve Tools addon (an addon for working with curves). I'm just working on expanding them. They are in this add-on in the panel. In the next update, I will add this functionality to the context menu.
Added context menu to CurveTools addon.
