Edit-mesh separate by loose parts stuck indefinitely #70864
Reference: blender/blender#70864
Graphics card: GeForce GTX 1080 with Max-Q Design/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 436.48
Broken: version: 2.82 (sub 0), branch: master, commit date: 2019-10-14 16:48, hash:
519891c669
The separate by loose parts tool hangs on large meshes.
Yes it's a fairly large mesh, but tools like select linked or even separate by selection do not have much problem with it. However separate by loose parts takes (forever?) I had to close Blender after 3 hours.
Separate.blend
Enter edit mode
Press P
Separate by Loose Parts
Automated test:
Added subscriber: @zanqdo
Separate by loose partsto Unreasonably high memory usage with edit-mesh separate by loose partsAdded subscriber: @ideasman42
Note that this was discussed in blender.chat, this report has some differences to the issue discussed in chat (not sure if the issue is memory usage or just being slow).
This file has 110,512 isolated vertices, each is creating a new object.
Copying the geometry is inefficient too, although it's not the root-cause of the problem.
Firstly to avoid this issue you could delete all isolated vertices.
As for how Blender could handle this better, we could do a pass for isolated verts/edges/faces and split them into a single object.
There might be some cases existing behavior is preferred, so that could be an option (off by default).
Unreasonably high memory usage with edit-mesh separate by loose partsto Edit-mesh separate by loose parts stuck indefinatelyEdit-mesh separate by loose parts stuck indefinatelyto Edit-mesh separate by loose parts stuck indefinitelyYou are right, it's the solo verts that are causing it to hang forever. After I removed them with a non manifold select operation it managed to separate quite quickly.
The problem with this is that lots of CAD files come with similar geometry so the operator just hangs for no apparent reason.
@zanqdo what do you think about the solution/workaround proposed above?
Having all isolated vertices into a single object by default sounds perfectly reasonable. Considering the trouble of creating thousands of single vert objects.
As mentioned on the chat. This would solve this test file but not a real use case where the mesh comes with thousands of valid parts (CAD Files). The split algorithm seems to be escalating really poorly until the point that you have to force quit Blender.
Something closer to the real test case would be useful to have (just randomize locations, it will work the same for our purposes).
This issue was referenced by
71538eaad6
