Library Override: Parenting library override objects does not save offset from parent.
Closed, ResolvedPublicBUG
Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 417.35
Broken: version: 2.81 (sub 15), branch: master, commit date: 2019-10-11 19:43, hash: rB60d02b336eaf
If you parent an object that is part of a collection which has been library overridden to something else, then next time the file is loaded the overridden object is offset from it's correct position, with the object's origin now being placed at the origin of the parent.
  1. make a library override of a collection of objects.
  2. Parent one of those objects to something like an empty (the empty should be anywhere but the origin)
  3. Save and reload the file.
  • open main.blend [has collection linked from lib.blend which was made a library override]
  • select, Torus, then select Empty, Ctrl+P Object
  • save
  • reopen, result should be the same as main_saved.blend (Torus origin is now at Empty's origin)
Zach Hixson (zachThePerson) renamed this task from Parenting library override objects leads to undesired offsets to Parenting library override objects does not save offset from parent. .Oct 20 2019, 1:22 AM
Zach Hixson (zachThePerson) created this task.
Zach Hixson (zachThePerson) updated the task description. (Show Details)
Philipp Oeser (lichtwerk) renamed this task from Parenting library override objects does not save offset from parent. to Library Override: Parenting library override objects does not save offset from parent. .Oct 23 2019, 3:06 PM
Philipp Oeser (lichtwerk) lowered the priority of this task from 90 to 50.Oct 23 2019, 4:11 PM
Hi, I'm still having this problem. I have a rig that is linked from another file. When I parent an object to a bone everything works well, but when I reload the file it's messed up. Nothing I tried seems to work. Any suggestion? Using Ubuntu 20.04.1 64bits Mate edition. Tried both Blender 2.85 and 2.9
I'm attaching my system specs{F8834537}
