UI: support 'activate_init' for popups which refresh #71112
8 Participants
Reference: blender/blender#71112
Currently 'activate_init' layout property doesn't work for popups which run their draw function multiple times once opened.
Operating system: Linux-5.3.7-arch1-1-ARCH-x86_64-with-arch 64 Bits
Graphics card: GeForce GTX 660M/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 435.21
Broken versions:
2.81 (sub 15), branch: master, commit date: 2019-10-24 19:00, hash:
892c3891ed
2.82 (sub 1), branch: master, commit date: 2019-10-24 19:11, hash:
2a3b5dc730
Setting the activate_init property of a UILayout causes weird behavior and often causes the blender ui to freeze. I'm including a test addon that utilizes activate_init in a panel, a popup, and an item within a UIList in a popup. Both the popup and the UIList item cause the whole ui to freeze after interacting with them, while the panel just isn't affected at all. The weird behavior only seems to happen after you press enter or otherwise finish interacting with the auto-activated field; everything acts like you would expect until you finish and find the UI is non-responsive.
The panel is named Test Panel and located in the Object tab of the Properties Editor.
The popup can be called by pressing ALT-T
The UIList can be called by pressing CTRL-T
Install and activate the test addon.
Press one of the hotkeys.
Press enter to finish editing the auto activated field.
Try to pan the 3D View using the middle mouse button.
activate_init_bug_test.py
Added subscriber: @Imaginer
Added subscriber: @joules-2
I can confirm this freezes the UI.
I came across a crash however trying to capture an event.
Regardless of activate_init enabled or not. Tried to capture an event (i.e {'ESC'}) with a modal() handler added with invoke() however blender will crash on modal(). Could be related or a case of don't do that with popups.
Added subscriber: @MiroHorvath
I can confirm that this is freezing the UI as well.
It does not crash or is completely unresponsive though.
The File Close Dialog is still working as usual (when you try to close Blender). So it looks like there is an issue with the event handling somewhere.
@Imaginer Can you explain what the
test
variable is supposed to do? While I haven't used theactivate_init
feature myself yet, your use of thetest
variable seems weird.Interestingly, when I remove it, I actually get a crash.
@JacquesLucke I'm a little foggy on the details, but if I recall correctly I used
test
to make sureactivate_init
was only set once (so ui redraws wouldn't set it multiple times) to try and improve the result (could have been to avoid the crash). Another reason you'd want something like this is to allowactivate_init
to only be set in certain situations. I put this demonstration addon together quickly and didn't use blender's bool properties or annotation syntax, but I just tested and it performs the same.Thanks for taking a look at this. :)
Using Activate Init in an Addon Causes the Blender UI to Freezeto UI: support 'activate_init' for popups which refreshChanged status from 'Needs Triage' to: 'Confirmed'
This issue was referenced by
0840469ccd
Added subscriber: @portnov
The freezing reproduces for me at Blender 2.90.1 and Blender 2.91
b00820c04d
. Was the fix included in some release?@portnov It works for me in 2.90.0, so maybe it's a regression. Since #75521 is still open it could also be related to that.
Perhaps it's hardware dependent?
