Strokes made in Texture Paint when camera is set perpendicularly to surface do not appear. #71122
5 Participants
Reference: blender/blender#71122
Operating system:Win10/Win7
Graphics card:gtx1070/hd620
Broken: (2.80, 2.82.1 2019-10-26)
Worked: 2.79
In perspective mode when camera is set perpendicularly strokes made in texture paint mode do not appear.
Create cube, uv unwrap, and texture. Go into perspective mode, position camera perpendicularly to one of cube faces. Make a stroke. It wont show up.
Rotate camera a bit and make stroke, it will appear. Looks like this gets worse if you come closer to surface.
Ive made video, pay attention to info from wacom driver about pressure on side thats the only way to know when im touching tablet.
https://youtu.be/2yZ588ad-f0
Regards.
Added subscriber: @riceart
Strokes made camera is set perpendicularly to surface do not appear.to Strokes made in Texture Paint when camera is set perpendicularly to surface do not appear.Added subscriber: @DavisSorenson
Confirmed on
c036db9f57ff
for a UV-unwrapped cube. However, I'm unable to reproduce the problem with any other primitive. I tried with Suzanne, but rotating the viewport camera so that it was perpendicular to a face didn't cause any problems. I also tried rotating the model so that a particular face was normal to the global positive Y axis, like the face of the cube in the video in the original report. That didn't reproduce the bug either.Removed subscriber: @DavisSorenson
Added subscriber: @mano-wii
Please provide a .blend file with the position saved for us to investigate.
It may well be related to the problem identified in #70128 (although it has no vertices behind the viewport).
added
bug.blend
ps. it was made with 2.80.75
ps2. and i can confirm that this but exists on linux version to.
I can confirm the bug, but I can't tell if it is related to #70128
Interesting that if I delete the remaining faces the problem seems to disappear.
I don't think it is related to #70128. I think it isn't a bug at all.
In the case the
Normal Falloff
test is failing as no vertices are selected as no vertice really points to the camera.It doesn't happen when
Normal Falloff
in the falloff is disabled.issue is inside
proj_paint_state_vert_flags_init
in the else clause ofif (ps->is_otho)
.The math is done in
object space
and ignores many variables.Code seems to be from the initial commit back in 2013.
The solution I have is to replace the perspective based implementation with the ortho one as this is better in handling these situations. Or remove the test at all when in perspective mode as it is selecting vertices to be evaluated later on. I prefer to replace it with the ortho one as perspective texture painting is more used and will have some performance benefit.
The other solution (actually fixing the issue) might need an overhaul of the system.
@ideasman42 what do you think what we should do with this issue?
Added subscriber: @ideasman42
Closed as duplicate of #42230
