Could not submit results (unable to connect) #71129
Closed
opened 2019-10-27 11:12:43 +01:00 by Greg · 4 comments
After running the blender benchmark I was unable to submit the results.benchmark-error-report.txt
The error said, unable to connect to the server.
benchmark-result.txt
After running the blender benchmark I was unable to submit the results.[benchmark-error-report.txt](https://archive.blender.org/developer/F7862190/benchmark-error-report.txt) The error said, unable to connect to the server. [benchmark-result.txt](https://archive.blender.org/developer/F7862189/benchmark-result.txt)
Greg self-assigned this 2019-10-27 11:12:43 +01:00
Author
Added subscriber: @Greeg
Added subscriber: @SemMulder
We just released a new version of the launcher which is available at https://opendata.blender.org/. If possible, can you try it using the new version?
Francesco Siddi changed title from Could nog submit results (unable to connect) to Could not submit results (unable to connect) 2020-01-14 11:59:18 +01:00
Reference: infrastructure/blender-open-data#71129
