Eevee preview nodes performance drop #71214
5 Participants
Reference: blender/blender#71214
Operating system:Windows 10
Graphics card: GeForce GTX 1060
Broken: Blender 2.81 Beta
aff6446e06
Worked: 2.8
Complex shader with large amount of math nodes slow down performance
in 2.8 60 fps
in 2.81 30 fps
Create material with 30 node groups contains 30 math nodes. Set viewport to material preview and watch performance droping NodesPerformanceDrop.blend
Added subscriber: @DanilaPryamonosov
Added subscribers: @fclem, @Sergey, @dfelinto, @mano-wii
I can confirm, but I don't know if the solution is simple.
The problem arose because now all the shader tree is flattened before evaluation.
But the main reason for slowness is because of animated materials (see
9d59d209
).Blender doesn't differentiate whether a material is animated or not, so the
BKE_material_eval
simply clears allgpumaterials
references with each frame change.Then
DRW_manager
needs to recreate thegpumaterial
, but first check for similar passes.And to do this check, it has to go through the entire node tree to create a hash.
And so finds the pass of the original
gpumaterial
.Removing this line, the problem is solved:
But then it would bring a problem for the animated materials.
It would be nice to find another solution for animated materials (updating only uniforms for example).
Assigning to @fclem, but @dfelinto and @Sergey may also have some remarks about it.
Part of the issue here is that material is not supposed to be re-evaluating on playback here.
The reason it was is because of some rather uncommon (in my experience) situation when ID has action but no f-curve. This can be fixed with something like P1149.
But there should be a way to speed up things even for the case when there is a real animation involved.
Not sure about current implementation, but we can calculate hash of every node group from dependency graph (which will happen in nice and threaded environment). We can even do things like constant folding and removal of unconnected nodes from there.
Now, even if that is still by-passed (imagine, that all the groups are connected and such) we can re-use hashes calculated for every group and use those to save on calculating hashes.
I was a bit hasty, the hash is not the problem (obtained from
GPU_generate_pass
),but it is
GPU_material_from_nodetree
in general (it should not even be called again),especially
ntreeGPUMaterialNodes
(68,66% of the frame time).If the material changes then i don't see how you can avoid
.Added subscriber: @StanislavOvcharov
dews any hope this bug will be fixed?
This can be a task for #68908 (Faster Animation Playback)
This has been fixed by
32f0bb0523
