Design: DrawManager Colormanagement #71357
7 Participants
Reference: blender/blender#71357
This task will go over improvements I want to suggest to the Draw Manager color management. This ticket is in discussion, in the hope to get viewpoints of experts about the subject.
The scope of this ticket is limited to the draw manager as there are some isolated issues here. After the design is approved, the engineering plan can be written. In the engineering plan we will go on the how and code-technical implications.
Current Situation
DrawManager is used in many areas with other target colorspace needs than currently available. DrawManager has a flag
do_colormanagement
, what can either be on or off. When its on, it is up to the draw engines to do the correct expected color management actions. Most of the time this has been implemented with a lot of assumptions about colorspace of the input and output.For example:
Usages of DrawManager
Issues
Proposal
Generated GLSL color transfer functions by OpenColorIO configuration.
common_colormanagement_lib.glsl
. Make the functions OpenColorIO role based. this way it is more clear what function to use in what situation. The role based approach would also limit the configurations that needs to be handled by the shader. But some color management pre-processing needs to be done when images are not using a space defined by the role there in.To be able to set a target OpenColorIO role, when drawing to an offscreen buffer. At the end of the drawing the offscreen buffer is then converted to the ColorSpace that is in the colormanagement configuration for that specific Role.
When rendering and compositing the linear scene ref space (default REC709) must be used. This means that the overlay/mode engines will be drawing in the reference soace and only as a last step the view transform will be applied.
Note that this will also impact how Grease pencil blends colors and there will be rendering differences. These differences are currently also noticeable during final rendering of GP projects. Images that are rendered in the background are currently fixed to REC709 or sRGB. other colorspaces are ignored. We should transform the image buffer from its own encoding to the scene linear space.
Make sure that when overlays are drawn, the input buffers are transferred to the expected color space (display), and transferred back afterwards. Note that color transfers are not reversible and that leads to other artifacts. This part still needs more thought.
Added subscribers: @Jeroen-Bakker, @fclem
Added subscriber: @EAW
Added subscriber: @sebastian_k
Added subscriber: @item412
Added subscriber: @frameshift
Many many kudos for the write-up. This would tackle a huge amount of the current issues.
But doing it on the GPU would be less accurate, you once told me. How inaccurate are we talking? Is it worth the trade-off?
Added subscriber: @MichaelHermann
Just to be on the safe side, I'd like to highlight some stuff in an attempt to prevent any hardcoding from being left behind.
REC709the reference space and only as a last step the view transform will be applied.color space to one of them (depends a bit on use)own encoding to the scene linear reference space.I just like the word encoding because it implies more than just primaries. For instance, if I have a Filmic image, it can only be converted to the scene linear space by inverting that Filmic Log transform. Its primaries are still Rec. 709's, but its encoding is far from sRGB or BT.1886.
Thanks updated. The more I look into the subject the more issues I detect. Might be that I start with some small steps. As some stuff that OCIO provides is a bit hidden behind a wrapper. Need to find out if we actually want this wrapper still to be used. I don't like wrappers that limits possibilities.
Ironically, that makes me very happy :D
I get that, but something tells me they're there for a reason..?
Added subscriber: @Memento
I have added #72420 (Design: DrawEngine Color Management) as a sub-task for discussing a first step.
Removed subscriber: @Memento
@Jeroen-Bakker Could you elaborate on why this design is invalid? I'm not super familiar with the internals of Blender, but describing the issue might help people understand.
Hi Sam,
At the end we came up with a different design to solve this issue. the final design all draw engines work in linear scene ref space. drawing results into 2 images for each eye (render engine image and overlay engine image). when drawing to the screen these images are composited and converted to display space. This all is done in the GPUViewport. Also external render engines should now render in linear ref space when showing in the viewport.
@Jeroen-Bakker sounds great, thanks!
