Memory leak if both a shader and an AddonPreferences class are used #71362
5 Participants
Reference: blender/blender#71362
Graphics card: GeForce RTX 2080/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 431.86
Broken: version: Official 2.80 (sub 75), branch: master, commit date: 2019-07-29 14:47, hash:
f6cb5f5449
Blender shows the warning
Error: Not freed memory blocks: 4, total unfreed memory 0.012421 MB
when an addon uses both AddonPreferences with an implementation of thedraw()
method and an instance ofgpu.types.GPUShader
.Exact steps for others to reproduce the error
blender.exe --factory-startup --addons memleak
.If you open the addon in a text editor and comment out line 30 (
shader = gpu.types.GPUShader(vertex_shader, fragment_shader)
), the error is no longer shown.Similarly, if you comment out lines 37 and 38 instead (
def draw(self, context): pass
) and leave line 30 enabled, the error will also not show up.Of course this problem might also be caused by other conditions, but those two (shader and AddonPreferences class) are the combination where I spotted the problem first.
Added subscriber: @BYOB
Added subscriber: @mano-wii
Although it is not recommended to create and keep a reference to an object type Shader in the top level of a module (shaders are slow to create and use a lot of GPU resources),
the fact that an object of type
AddonPreferences
results in a memory leak indicates that somewhere in the creation of such object has a wrong refcount.This is something that deserves investigation but doesn't have much priority.
Why would that be a problem? This code is executed exactly once at Blender startup.
(This is a bit off-topic, but I would appreciate to learn more about this comment)
Added subscriber: @dr.sybren
Python doesn't always free everything cleanly when the program quits. The memory leak could be due to having any registerable classes in the module, which could impact the order in which things are freed.
I tested the above, and the problem doesn't occur when replacing the
bpy.types.AddonPreferences
superclass with abpy.types.Panel
orbpy.types.Operator
.It's also re-executed when reloading scripts.
I would recommend allocating things in the
register()
function instead, and freeing inunregister()
. This is what I do in the Blender Cloud add-on, for example: https://developer.blender.org/diffusion/BCA/browse/master/blender_cloud/attract/draw.py. This doesn't resolve this issue, but at least you only create the shader when the add-on is enabled.Added subscriber: @Jeroen-Bakker
The
register
/unregister
does not fix the issueP1398: (An Untitled Masterwork)
Interesting that commenting out the draw method fixes the issue or using a different base class. I also tried some variations with class variables.
Added subscriber: @ideasman42
This report is it's behavior depends on Python's GC, in general that shouldn't be something we worry about unless it's really a leak,
OTOH, that it causes Blender to report leaks isn't good. That there doesn't seem to be a reliable workaround isn't good either.
On testing P1398, I can't redo the error, it never leaks after unregister is called.
I suspect Python's GC isn't cleaning up after calling
unregister
in some situations.Does this patch resolve the issue?
I've committed a change to call
unregister
at exit, since it's quiet fast and allows us to avoid false positive resource leaks.fa566157a5
.Changed status from 'Confirmed' to: 'Resolved'
This patch does not solve the issue, but with
fa566157a5
I can't reproduce the problem anymore.So I believe we can consider it resolved by that commit :)
