XYZ Function Surface problem #71543
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#71543
Operating system: M$ Windows 10
Graphics card: Intel 4000
Broken: 2.80, 2.81, 2.82
XYZ Function Surface, Globoid creation no longer working (just produces a point like object)
It is working correctly in 2.79b, it was working in the 2.80 release of about last February but is not working in the current (July 2019) release of 2.80 nor in 2.81 Beta nor 2.82 Alpha
Add new XYZ Function Surface
Uncheck U wrap
Set V min and V max : 0
Set V step : 1
Go to the calculator on http://www.otvinta.com/globoid.html
Put in some values. for example
Module : 1
Arc Angle : 60
Gear Teeth : 8
reference Radius 5
Click [Calculate Equations] button
Using these example values, the following equations are created by the calculator
X : - (29 - 23 * cos(u * pi / 6 - 0.0183)) * cos(u * pi * 8)
Y: - (29 - 23 * cos(u * pi / 6 - 0.0183)) * sin(u * pi * 8)
Z: - 23 * sin(u * pi / 6 - 0.0183)
Also enter
U min : -1
U max : 1
U Step : 1024
Expected: a helical curve as per the screen shot
Actual: a point like object
Added subscriber: @les_kaye
This issue was referenced by
d803b6c6f5
This is not a bug in the addon.
The addon creates the desired grid, but it does not appear in solid mode. Faces are zero size.
To avoid further questions, I added a display of the created object with wire enabled (a custom option).
