rB0666ece2e2f9 (Cloth: collision improvements) breaks particle collisions with moving meshes #71620
Closed
opened 2019-11-16 04:24:49 +01:00 by Kevin Buhr · 13 comments
Operating system: Linux-4.15.0-70-generic-x86_64-with-debian-buster-sid 64 Bits
Graphics card: GeForce GTX 1080/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 440.26
Broken: version: 2.80 (sub 75), branch: master, commit date: 2019-07-29 14:47, hash: 0666ece2e2
Worked: 2.79
Particles created inside a moving collision object can "leak out" until the object comes to rest.
This may be related to #68128, but I wasn't able to get the .blend files there to work properly with the Blender versions near the guilty commit (see below).
The guilty commit is 0666ece2. The particles stay inside the sphere before this commit and leak out after.
Open:
T71620_test.blend
  • Run animation.
  • Notice how many particles fail the collision.
In blender 2.79 none of the particles fail.
**System Information** Operating system: Linux-4.15.0-70-generic-x86_64-with-debian-buster-sid 64 Bits Graphics card: GeForce GTX 1080/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 440.26 **Blender Version** Broken: version: 2.80 (sub 75), branch: master, commit date: 2019-07-29 14:47, hash: 0666ece2e2 Worked: 2.79 **Short description of error** Particles created inside a moving collision object can "leak out" until the object comes to rest. This *may* be related to #68128, but I wasn't able to get the .blend files there to work properly with the Blender versions near the guilty commit (see below). The guilty commit is 0666ece2. The particles stay inside the sphere before this commit and leak out after. **Exact steps for others to reproduce the error** Open: [T71620_test.blend](https://archive.blender.org/developer/F8099781/T71620_test.blend) - Run animation. - Notice how many particles fail the collision. In blender 2.79 none of the particles fail.
Author
Added subscriber: @buhr
Author
Author
The specific part of the commit that seems to cause the problem is this bit:
diff --git a/source/blender/blenkernel/intern/collision.c b/source/blender/blenkernel/intern/collision.c
index 183a4f9a181..d0eac3bb713 100644
--- a/source/blender/blenkernel/intern/collision.c
+++ b/source/blender/blenkernel/intern/collision.c
@@ -74,7 +89,7 @@ Collision modifier code start
 /* step is limited from 0 (frame start position) to 1 (frame end position) */
 void collision_move_object(CollisionModifierData *collmd, float step, float prevstep)
-	float tv[3] = {0, 0, 0};
+	float oldx[3];
 	unsigned int i = 0;
 	/* the collider doesn't move this frame */
@@ -87,15 +102,14 @@ void collision_move_object(CollisionModifierData *collmd, float step, float prev
 	for (i = 0; i < collmd->mvert_num; i++) {
-		sub_v3_v3v3(tv, collmd->xnew[i].co, collmd->x[i].co);
-		VECADDS(collmd->current_x[i].co, collmd->x[i].co, tv, prevstep);
-		VECADDS(collmd->current_xnew[i].co, collmd->x[i].co, tv, step);
-		sub_v3_v3v3(collmd->current_v[i].co, collmd->current_xnew[i].co, collmd->current_x[i].co);
+		interp_v3_v3v3(oldx, collmd->x[i].co, collmd->xnew[i].co, prevstep);
+		interp_v3_v3v3(collmd->current_x[i].co, collmd->x[i].co, collmd->xnew[i].co, step);
+		sub_v3_v3v3(collmd->current_v[i].co, collmd->current_x[i].co, oldx);
 	bvhtree_update_from_mvert(
-	        collmd->bvhtree, collmd->current_x, collmd->current_xnew,
-	        collmd->tri, collmd->tri_num, true);
+	        collmd->bvhtree, collmd->current_x, NULL,
+	        collmd->tri, collmd->tri_num, false);
 BVHTree *bvhtree_build_from_mvert(
If this change is backed out (or altered to preserve the original semantics), particle collisions stop leaking. The trouble is, I can't tell what the motivation was for making this change in the first place.
The specific part of the commit that seems to cause the problem is this bit: ``` diff --git a/source/blender/blenkernel/intern/collision.c b/source/blender/blenkernel/intern/collision.c index 183a4f9a181..d0eac3bb713 100644 --- a/source/blender/blenkernel/intern/collision.c +++ b/source/blender/blenkernel/intern/collision.c @@ -74,7 +89,7 @@ Collision modifier code start /* step is limited from 0 (frame start position) to 1 (frame end position) */ void collision_move_object(CollisionModifierData *collmd, float step, float prevstep) { - float tv[3] = {0, 0, 0}; + float oldx[3]; unsigned int i = 0; /* the collider doesn't move this frame */ @@ -87,15 +102,14 @@ void collision_move_object(CollisionModifierData *collmd, float step, float prev } for (i = 0; i < collmd->mvert_num; i++) { - sub_v3_v3v3(tv, collmd->xnew[i].co, collmd->x[i].co); - VECADDS(collmd->current_x[i].co, collmd->x[i].co, tv, prevstep); - VECADDS(collmd->current_xnew[i].co, collmd->x[i].co, tv, step); - sub_v3_v3v3(collmd->current_v[i].co, collmd->current_xnew[i].co, collmd->current_x[i].co); + interp_v3_v3v3(oldx, collmd->x[i].co, collmd->xnew[i].co, prevstep); + interp_v3_v3v3(collmd->current_x[i].co, collmd->x[i].co, collmd->xnew[i].co, step); + sub_v3_v3v3(collmd->current_v[i].co, collmd->current_x[i].co, oldx); } bvhtree_update_from_mvert( - collmd->bvhtree, collmd->current_x, collmd->current_xnew, - collmd->tri, collmd->tri_num, true); + collmd->bvhtree, collmd->current_x, NULL, + collmd->tri, collmd->tri_num, false); } BVHTree *bvhtree_build_from_mvert( ``` If this change is backed out (or altered to preserve the original semantics), particle collisions stop leaking. The trouble is, I can't tell what the motivation was for making this change in the first place.
Member
Added subscriber: @lichtwerk
Member
note there was also a problem regarding hair collisions that was caused by culprit commit 0666ece2 [this was hopefully fixed in e52ad1835a, might give a hint on this issue as well...]
Member
Seems like this will do [but atm. I am on the same page as @buhr -- in that it is unclear why that change was made for cloth]
P1165: T71620_snippet
index 91d66e16dde..51d0c4703d4 100644
@@ -98,7 +98,7 @@ void collision_move_object(CollisionModifierData *collmd, float step, float prev
-      collmd->bvhtree, collmd->current_x, NULL, collmd->tri, collmd->tri_num, false);
+      collmd->bvhtree, collmd->current_x, collmd->current_xnew, collmd->tri, collmd->tri_num, true);
 BVHTree *bvhtree_build_from_mvert(const MVert *mvert,
(basically it looks like [for cloth?], the points are not considered moving anymore -- thus their KDTree node is not expanded anymore... needs some further investigation...)
(personally I would consider this a High priority, but the particle system is EOL... so will leave up to others...)
Seems like this will do [but atm. I am on the same page as @buhr -- in that it is unclear why that change was made for cloth] [P1165: T71620_snippet](https://archive.blender.org/developer/P1165.txt) ``` diff --git a/source/blender/blenkernel/intern/collision.c b/source/blender/blenkernel/intern/collision.c index 91d66e16dde..51d0c4703d4 100644 --- a/source/blender/blenkernel/intern/collision.c +++ b/source/blender/blenkernel/intern/collision.c @@ -98,7 +98,7 @@ void collision_move_object(CollisionModifierData *collmd, float step, float prev } bvhtree_update_from_mvert( - collmd->bvhtree, collmd->current_x, NULL, collmd->tri, collmd->tri_num, false); + collmd->bvhtree, collmd->current_x, collmd->current_xnew, collmd->tri, collmd->tri_num, true); } BVHTree *bvhtree_build_from_mvert(const MVert *mvert, ``` (basically it looks like [for cloth?], the points are not considered moving anymore -- thus their KDTree node is not expanded anymore... needs some further investigation...) (personally I would consider this a High priority, but the particle system is EOL... so will leave up to others...)
Member
Added subscribers: @LucaRood-3, @brecht
Member
Been reading code a bit, I think this might boil down to this statement from D3712: Cloth: improved collisions:
Use static BVH overlap, to reduce false positives, as moving collisions are not computed anyway.
This might be true for cloth, it seems it is not for particles (havent checked hair here, but this might be the reason for some reports on hair...)
CC @LucaRood-3
CC @brecht`
Been reading code a bit, I think this might boil down to this statement from [D3712: Cloth: improved collisions](https://archive.blender.org/developer/D3712): > Use static BVH overlap, to reduce false positives, as moving collisions are not computed anyway. This might be true for cloth, it seems it is **not** for particles (havent checked hair here, but this might be the reason for some reports on hair...) CC @LucaRood-3 CC @brecht`
Germano Cavalcante changed title from D3712 (Cloth: collision improvements) breaks particle collisions with moving meshes to rB0666ece2e2f9 (Cloth: collision improvements) breaks particle collisions with moving meshes 2020-01-10 15:33:00 +01:00
Member
Added subscriber: @mano-wii
Member
@LucaRood-3 : @mano-wii suggested to isolate the change of P1165 to only affect particles, doublecheck and maybe commit. Opinions?
@LucaRood-3 : @mano-wii suggested to isolate the change of [P1165](https://archive.blender.org/developer/P1165.txt) to only affect particles, doublecheck and maybe commit. Opinions?
Member
Sorry for the late reaction. I somehow completely missed this task before.
Indeed I seem to have overlooked particle collisions when implementing that optimisation.
I now submitted D6560 which is basically what @lichtwerk and @mano-wii proposed, but with the added update of current_xnew and current_x.
Btw, for future reference, this issue was caused specifically by fe9debc47b, which is one of the commits that eventually got squashed into 0666ece2.
Sorry for the late reaction. I somehow completely missed this task before. Indeed I seem to have overlooked particle collisions when implementing that optimisation. I now submitted [D6560](https://archive.blender.org/developer/D6560) which is basically what @lichtwerk and @mano-wii proposed, but with the added update of `current_xnew` and `current_x`. Btw, for future reference, this issue was caused specifically by fe9debc47b, which is one of the commits that eventually got squashed into 0666ece2.
This issue was referenced by 0ef881cc57
This issue was referenced by 0ef881cc57829471c441367ada6bf88119eaf26a
Member
Luna Rood self-assigned this 2020-01-12 17:26:44 +01:00
Reference: blender/blender#71620
