Alembic: low performance playback when keyframing object visibility #71740
Reference: blender/blender#71740
Graphics card: GeForce GTX 1080 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 441.20
Broken: version: 2.81 (sub 16), branch: master, commit date: 2019-11-20 14:27, hash:
26bd5ebd42
Worked: 2.80
I just opened my current project and playback dropped from 40fps (in Blender 2.80) to 13fps (in 2.81). I found that problem is with hidden animated (or drivered) object. If you animate (or drive) viewport visibility, it take performance similar to showed this object.
You can try it with this scene:
playback.blend
playback.abc
Added subscriber: @Cenda
Hello, any news with this? I would like to use 2.81 in my current project, but I can not, because performance is really bad.
btw. problem is not related to Alembic, even I use some character rig, it take many frames when it is hidden.
If it is not related to alembic, could you then prepare a new simpler example to reproduce the issue?
Just tried reproduce it without alembic, but it looks ok. So sorry problem is only with hidden alembic.
for workaround I turned off visibility in the viewport in source file:
Changed status from 'Needs User Info' to: 'Needs Developer To Reproduce'
Added subscriber: @dr.sybren
Changed status from 'Needs Developer To Reproduce' to: 'Confirmed'
This seems to be related to the keyframe animation on the viewport visibility of the objects. If I remove those FCurves, the performance is good (40-ish FPS on my machine). When the viewport visibility is keyframed, performance drops to 12-ish FPS on my machine.
I can also confirm that Blender 2.80 with the FCurves still there has the same performance as current 2.82 (
1f6ab32196
) with the FCurves removed.Low performance playbackto Alembic: low performance playback when keyframing object visibilityChanged status from 'Confirmed' to: 'Archived'
The slower performance is due to the new mesh normals handling introduced in
e9c149d911
. Mesh normals from Alembic were previously ignored by Blender; loading & handling them properly now takes time. This is to be expected. If smooth shading is good enough, and more detailed normals aren't necessary, export the Alembic without mesh normals and it should go back to the old performance.The effect of animated visibility on modifier evaluation is a known limitation of the current Blender architecture. This is commented on in DepsgraphBuilder::need_pull_base_into_graph(), which determines what is to be evaluated and what isn't:
As a workaround you could put a driver on the viewport visibility and let it target the modifier enabled flag (the opposite is harder to do due to the visibility being stored per-object-per-viewlayer layer and not just per-object).
I'm closing this as a known issue (the status "Invalid" only indicates "closed but not resolved"; your remark that performance has gone down is still valid) as this is a limitation of the current design, and not a bug in Blender as such.
