Affect Origins can have bad Performance / feature gives unexpected results. #71827
2 Participants
Reference: blender/blender#71827
Graphics card: GeForce GTX 980 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 436.48
Broken: version: 2.81 (sub 16), branch: master, commit date: 2019-11-20 14:27, hash:
26bd5ebd42
The New Affect Origins option in 2.81 + is very nice to finally have! But, I noticed some things as I started to use it.. If your mesh is pretty dense (high poly) it can be quite laggy to move the pivot around the viewport, since it appears to re-eval the mesh as the pivot changes, per frame?
It seems like it might be better to only update the mesh transforms at the very end/when committing, but I'm not sure if that can be easily done or not.
I had made my own Addon to do this exact thing, before the Affect Pivots feature was added, and I only updated the pivot when the user finally commited it, to avoid that kind of thing.
It also looks like the Gizmo doesn't stay relative size to the viewport. So if you zoom in and out, or work at a smaller or larger scale it can be TOO big or TOO small when trying to adjust things.
I also notice that if you rotate the Origin/Gizmo, you can see the Rotation Values reflected in the Item/transform tab, but if you then try to change those numbers directly in that UI area, the WHOLE object actually rotates and not the origin/gizmo as you'd expect.
Affect_Origins_Performance_Issues.blend
Added subscriber: @mattli911
Added subscriber: @mano-wii
While it is good to have these performance improvements, this report is not about a regression and the code works as designed.
For suggestions on how to improve the code, please use other channels to contact the developers:
https://wiki.blender.org/wiki/Communication/Contact#Contact_Developers
You can also propose a patch to be reviewed:
https://developer.blender.org/differential/diff/create/
You are more likely to have your request heard if you use these means.
