Changing manipulators is broken in the pie menu on 2.81 #71885
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
5 Participants
Reference: blender/blender-addons#71885
Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 416.34
Broken: version: 2.81 (sub 16), branch: master, commit date: 2019-11-20 14:27, hash:
blender/blender@26bd5ebd42
Addon Information
Name: 3D Viewport Pie Menus (1, 2, 9)
Author: meta-androcto
The changing of manipulators seem to be broken on 2.81 with the pie menu. When I try to change between manipulators using Alt - Space, it doesn't do anything.
First I select an object and with the Alt+Space key shortcut I open the pie menu with manipulators. Then I try to select one from the selection which is not currently used, however the manipulator does not switch to the chosen manipulator and stays unaffected.
Added subscriber: @MirekDusin
#79396 was marked as duplicate of this issue
Added subscriber: @Stan_Pancakes
Works here. Make sure you're not using an active tool (move, rotate, scale). These take precedence over the old manipulators.
Added subscriber: @BrendonMurphy
hi, I'm unable to reproduce this error. I'm using Blender 2.81 release and have tested your report and everything appears working. I did notice that the "w manipulators" operator pop up menu has the "Extend" option. It's needed to hold shift when this is active to show multiple manipulators at once. Is there anything you may have done? Any settings you have made that may cause the addon to fail? Any conflicting other addons hotkeys?
Could you try with a default "Factory Settings" and see if that works?
Oh, Stanislav is right, I was having an active tool selected and did not know that the pie menu is using the old manipulators. So it kind of works, although it is really confusing.
ahh, that makes sense, I'll try to have a look soon and see if I can fix this.
Just a quick follow up, we have the same behavior when using the viewport gizmo's. The active tools seems to over-ride them.
Select an active tool Move/Rotate/scale and the viewport gizmo's have no effect. This is the same as in the manipulator pie's behavior.
It is rather confusing yes.
Added subscribers: @kcd, @PratikPB2123
