Cycles Bake Selected to Active with transparency gives undesirable results #72085
Reference: blender/blender#72085
System Information:
Operating system: Windows-8.1-6.3.9600 64 Bits
Graphics card: GeForce GT 635M/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 391.35
Broken: version: 2.81 (sub 16), branch: master, commit date: 2019-11-20 14:27, hash:
26bd5ebd42
Bug or unintended behavior:
Baking using "Selected to Active" does not take into account transparency
How to reproduce:
Create two objects with materials and textures assigned to each;
In the shader editor, modify the material of the object with a transparency channel
In render properties, enable Selected to Active and use an appropriate ray distance
Result:
When baking combined or most channels, the transparent areas will assume the color as if it were completely opaque,
When baking normals with transparency, the transparent areas will mix with the normal of the geometry that is being baked to the active selection.
Both outcomes are unfavorable when working with transparent cards/ribbons.
bugreport.blend
I packed the textures edited the project to make the issues that I am having more clear.
{F8286028, size=full}
There are now 3 overlapping objects with transparency.
After baking normals or color, none of the colors or normals behind the transparent objects appear because the object appears to draw over top without transparency.
This example also shows that with full normal transparency, the normal will then be the geometry normal of the object rather than a flat normal or anything that is below the object.
Added subscriber: @Frautcres
Added subscriber: @mano-wii
Is this similar to #50698?
Issue referenced appears to be about color mixing
The project referenced can be slightly modified and shows the problem still exists pre-2.80
Left is the diffuse bake with overlapping quads drawing completely opaque overtop of each other, right is the render viewport, which is what I would have expected the bake to do.
{F8188468, size=full}
@Frautcres Your file is missing texture files. Please pack those into the file and upload it again.
@JacquesLucke I have packed the textures and modified the project slightly in order to show the issues that I am having more clearly.
Added subscriber: @brecht
This use case is just no supported by the implementation at all, it would require major changes to make baking take into account multiple objects for a single pixel.
