Broken: 2.81, 2.82
If during a transform you use the modal shortcut to toggle snapping, the snapping icon in the header will not update its state, even after the transform is confirmed or cancelled. It will update if you hover mouse pointer over it though.
- Load the default scene.
- Start moving the cube and press the snap toggle shortcut (shift+tab in default keymap)
- Complete or cancel the transform.
- Hover mouse pointer over the snap icon in the header.
