Cycles CUDA+CPU results in different random output per rendering tile
Open, Confirmed, MediumPublic
Graphics card: Quadro M4000/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 411.63
Broken: version: 2.82 (sub 3), branch: master, commit date: 2019-11-30 17:33, hash: rBf1ac64921b49
Cycles appear to produce different random values for CUDA tiles and CPU tiles.
Open
and compare rendered view with rendered output.
Images of the bug in isolation.
CPU Only - Fine:
CUDA Only - Fine:
CPU + CUDA - Bugs out:
In addition, I had some even more strange artefacts in a real render.
The random effect is more subtle here, but it's there. But the other ones I can't really reproduce, not sure what is going on with that:
I can't update drivers, due to other software requiring certain certified drivers. Windows 10 is up to date.
Germano Cavalcante (mano-wii) lowered the priority of this task from Needs Triage by Developer to Confirmed, High.Wed, Dec 4, 4:19 PM
It is also possible to reproduce the problem with OpenCL
I was able to reduce the material to this simple setup:
The file simplified:
Just to tidy things up... can somebody confirn, that the bug I have documented in T69535: CPU + GPU render precision differences for small, far away area light is the same one like this here? At least it looks pretty similar to me.
It is very similar, I will merge here to keep as a reference.
If when this is resolved, any of the other reports are not fixed, they will be reopened.
So far the similar reports are: T69535, T70501 and T70712
Brecht Van Lommel (brecht) lowered the priority of this task from Confirmed, High to Confirmed, Medium.Fri, Dec 6, 7:32 PM
