Fireflies with Environment Map Sampling Resolution Set To "Auto" #72314
Reference: blender/blender#72314
Operating system: Linux-5.3.15-050315-generic-x86_64-with-debian-buster-sid 64 Bits
Graphics card: GeForce GTX 1080 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 440.36
Broken: version: 2.82 (sub 4), branch: master, commit date: 2019-12-09 18:18, hash:
62ef59aa0c
and Official 2.81aWorked: None
Very noisy results with environment maps when using the default "Auto" resolution for the importance map
It's just a simple sphere with a Principled shader on it entirely lit by the 1024x512 pixel "sunset.exr" coming with Blender 2.8x (based on the "Venice Sunset.hdr" available at the HDRIHaven website)
The problem becomes more obvious the higher the dynamic range of the HDR / environment is. There are some HDRs where everything works fine OOTB but some are really showing extreme fireflies. I tried to use an HDR coming with Blender for the sake of simplicity but there are examples at HDRIHaven or other sites where the results look much worse than this.
Maybe the "Auto" setting should be set to 2x the horizontal resolution of the HDR?
Added subscriber: @SteffenD
Here's a blend file that more clearly shows the problem (also based on a CC0 texture from HDRI Haven).
Just press F12 and see the fireflies, now switch the sampling to "Manual" (which I set to 2048 = twice the horizontal resolution of the environment map) and all is fine with the same amount of samples and no clamping needed.
Fireflies_v02.blend
With "Auto" samples:
With "Manual" samples set to twice the horizontal resolution:
Added subscribers: @brecht, @JacquesLucke
I don't know what "Auto" is doing exactly. I'm not sure if the default settings for cycles have to provide a noise free result. I'd guess that for any resolution it is possible to find examples that result in a noisy result, but I'm not sure.
I don't think this is a bug, so I'm closing this.
@brecht, do you think the behavior of "Auto" should be changed as described above?
Hi there!
I know it's not a high priority issue as I can always do it the "old skool" way and set the resolution manually.
I just thought it was worth reporting here because now that Blender 2.8 is getting a lot of attention and new users, the feature (set to "Auto" by default) might cause a lot of reports and disappointment. I have some HDR environments that show a lot more fireflies than the ones I posted. They might be special cases or rather extreme, but if it even happens with the HDRs coming with Blender, that will cause trouble IMHO.
@JacquesLucke : The "Auto" settings just takes the horizontal resolution of an image and uses it as the "Map Resolution".
I can post some example HDRs that completely change the look of a render if set to "Auto" compared to "Manual" set to double the horizontal resolution.
Added subscriber: @filibis
